Home > General > Loving my cooled seats in this weather !
GGDR
Been a bit warmer finally - and even when I hit the 'max ac' button the greenhouse, I mean Range Rover - takes quite a while to cool down.
So fired up the cooled seat a couple of times in the last few days and its... well really really nice to have a cooled backside! And leg and back - while the AC gets the temperature down.
The is my first Range Rover and the driver / interior experience is something else. I've never had a car with this kind of luxury and whilst warmed seats made sense and have been great, I never really thought much about cooled seats... But they are so great !
All adds to the amazing Range Rover experience!
So here's to turning the seat dial to the left!
. Cheers, Greg
Post #439730 26th May 2017 9:05pm
andygts
Best invention ever, I use mine quite alot.
Thankfully I also had the aircon regassed the other week so mine really is like a fridge on wheels. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #439737 26th May 2017 9:23pm
Freddie The Fish
United Kingdom 2011 Range Rover SE 4.4 V8 Fuji White
In my previous cars even with AC full on you'd still finish you journey stuck to the seat, cool seats stop that.
Post #439738 26th May 2017 9:32pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
How cool do the cooled seats get, used mine for the first time yesterday and I could feel a bit of cold air on the base, but nothing in the back! Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #442155 20th Jun 2017 10:07pm
GGDR
You can have it on: BASE / BACK / BOTH so hit the button on the front of the dial and see if that makes sense.
 Cheers, Greg
Post #442158 20th Jun 2017 10:18pm
stu
Thanks for the reply, I had both the base and back lights on and all the blue lights on for max cooling! Will have a fiddle and compare the passengers to drivers seat as well Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #442161 20th Jun 2017 10:24pm
GGDR
There is also a round filter that can use a clean out once in a while. Raise your seats up to max, stick your head under and you'll see it. A quarter turn removes it. Cheers, Greg
Post #442162 20th Jun 2017 10:36pm
Freddie The Fish
Mine take a few minutes to kick in and are not that cold, just enough to stop a sweaty crevice
Post #442163 20th Jun 2017 10:43pm
The peltier cells don't have much range, about 7º below ambient and 9º above so the cooler you get the car the colder they will blow. 2008 MY Supercharged
Post #442175 21st Jun 2017 9:13am
stu
thanks for all the answers, I located the filters and twisted them off this morning, don't look over dirty but suppose it would do no harm to change them, probably won't cost that much to replace.
Are the seats in vse/ab the same as in a vogue apart from the leather?
my vogue was speced with heated and cooled seats. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #442184 21st Jun 2017 11:33am
Then you would have the Oxford leather sir,semi aniline was reserved for the VSE/AB even with the climactic seat option. 2008 MY Supercharged
Post #442186 21st Jun 2017 12:15pm
nino_nino
Bosnia Herzegovina 2012 Range Rover Autobiography Black TDV8 Santorini Black
stu, no need to buy new filters, first vacuum filters well and than sok them in the mild soapy water, rinse and dry. good as new.
Post #442190 21st Jun 2017 1:07pm
stu
@Axle.. thanks for that! it's hell being in second class you know.. Rolling with laughter
@nino_nino.. sounds like a plan thanks very much for that.. Bow down Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #442192 21st Jun 2017 1:20pm
