Home > Maintenance & Mods (L322) > 4.4 TDV8 Turbo Twin Oil Drain Pipe Modification - DIY?
Page 4 of 5 <12345>
GGDR
so how do we find out?
sump from a breakers?
. Cheers, Greg
Post #520788 5th Jul 2019 9:11pm
GGDR
actually is it sump or block?
. Cheers, Greg
Post #520789 5th Jul 2019 9:13pm
GraemeS
Australia
The holes are in the sump.
The lower hole presumably goes right through because of the length of the rod and that the rod with its bush must not be pulled out before all swarf has been flushed implying that the swarf would otherwise end-up inside.
I would also expect that the drill bit would take far too much effort to use unless it is only opening-out an existing hole even though drilling in aluminium rather than cast iron.
The instructions state to position a container to collect oil prior to removing the core plugs, although I would expect oii only to emerge from the lower plug as the upper hole drains to the lower hole through the tube through which the swarf is flushed.
Post #520797 5th Jul 2019 10:16pm
GGDR
Like your thinking, makes sense. Thumbs Up
Maybe safest to try to buy a sump from a breakers and plan it. Cheers, Greg
Post #520804 5th Jul 2019 10:51pm
GGDR
Found one on ebay:
https://www.ebay.co.uk/itm/2010-2012-RANGE...%7Ciid%3A1
See the two plugs on one above the other on the left (in this pic)
I reckon I need a buddy on tis one, anybody with any engineering experience want to help? Very Happy
. Cheers, Greg
Post #520991 7th Jul 2019 7:01pm
GGDR
Studying the top view, I can see what I think to be a vertical gallery:
This does seem to line up with the plugs.
Not sure what the plug is just above the gallery hole...
Quite invaluable to see this.... Cheers, Greg
Post #521003 7th Jul 2019 7:49pm
GGDR
Just picking this thread up - and a bit of a bump
That sump pictured could be had for around (hopefully under) £300.
Anyone with any engineering experience want to want to come in with me?
Greg
. Cheers, Greg
Post #524382 10th Aug 2019 3:42pm
Baltic Blue
Just out of interest Greg, Have you checked on the availability of the mod kit ? New pipe, drill jig etc. and the price ??
Add that to your 2nd hand sump and it may be that the indi price is not worth the hassle of a DIY job ?
Post #524385 10th Aug 2019 3:53pm
GGDR
Maybe four of us non-drainers could go in Surprised
Slicing the cost.
But your'e right I do need to check the kit price. Thumbs Up
(It's also about a win for the privateers) Cheers, Greg
Post #524386 10th Aug 2019 4:02pm
AJGalaxy2012
Good luck guys, Ive done a lot of spanner work in my time but this job outside on a drive with no ramp was a definite no no for me. Having seen the strip down they did at Green Oval I know I made the right decision. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #524393 10th Aug 2019 5:25pm
MisterT
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
I've done a lot of diy on my cars over the years, but decided this would be a step too far. Fortunately the dealer I bought from agreed to pay for the drain mod under warranty and Duckworths Boston carried out the work a couple of weeks ago.
They quoted £1279.20 all in (incl VAT). The kit part of the cost was £261. It took them a full two days even with all the kit in a main dealer workshop, and they even carried out a full four wheel alignment, when the work schedule only calls for the front tracking to be done.
Now it's done no more smoke screens, very pleased.
Just like to give a big Thumbs Up for Redline Specialist Cars in Harrogate who I bought from and their no quibble approach to dealing with warranty issues, IME they are a quality outfit with excellent customer care.
Duckworths Boston have also been very good and I will no doubt use them for service as there don't seem to be many LR specialist independents around South Lincs.
Post #524421 10th Aug 2019 10:48pm
GGDR
Agree it's a size niner job and I'm not ready to launch in and drill my sump yet...
But I do think there is a way other than the factory instructions which are belt and braces.
You've just got to get oil into the the plug hole. A plumbing job right?
Hence a test on a sump from a breakers being next step without drilling anything on the car (yet).
. Cheers, Greg
Post #524425 10th Aug 2019 11:16pm
its me
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Slicing the cost.
I'll have a 25% share of this so only need two others to join us!! 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion
Post #524452 11th Aug 2019 1:11pm
Ahem, don’t you have an SC sir? (It’s me)
Post #524466 11th Aug 2019 5:53pm
its me
Your quick Craig. Just updated my profile. I now have a 2011 4.4 tv8 with a Kahn bodykit,wheels and exhaust. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion
Post #524467 11th Aug 2019 6:15pm
Page 4 of 5 <12345>
