Home > Technical (L322) > IID tool confused........!!!
Rob99
Had a restricted performance message the other day (curious as performance wasn't actually restricted) and plugged in IID tool to check it out today. Only engine fault was water in fuel logged at about the right time but nothing since. Any thoughts?
Also, while looking through the various IID functions (hence the heading!) came across some relating to gearbox and it says I have a 6sp box not an 8sp box Shocked
Clearly I have an 8sp box but wondered if anyone else has spotted this obvious flaw......!!! 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #456068 4th Nov 2017 12:39am
i'd make sure your iidtool is up to date, and read the faults again Rob..
as for the error ,i'm sure someone else had the 'water in fuel' problem recently but i cant remember the outcome..
edit, here's the thread,
http://www.fullfatrr.com/forum/topic44830....water+fuel
theres ref to a sensor here,
http://www.fullfatrr.com/forum/topic43835....water+fuel
and here,
http://www.fullfatrr.com/forum/topic35253....water+fuel ... - .- -.
Post #456079 4th Nov 2017 10:18am
Rob99
Thanks Stan, I did check for the latest firmware a couple of weeks ago but will have another look later.
Thumbs Up 2021 D350 Fifty Edition - Carpathian Grey
Post #456200 5th Nov 2017 9:07am
