![]() | Home > Technical (L322) > Power steering using vacuum pump. |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
Nino as I said before you're impressively equipped for anything.
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690
With air box out = planty of space to take out power stearing reservoar for cleaning.
| Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 180
Nice writeup
Thanks, good point, corrected |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Can PAS fluid be changed by just siphoning off the reservoir multiple times over a few days then topping up/lock to lock every time it's siphoned off? I don't have the skills to replicate Nino |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Yes, I have done that successfully on my TDV8 and my Volvo. I used a large syringe with a bit of pipe to suck the fluid out of the reservoir, filled reservoir with new fluid, then used the car for a bit to circulate fluid, then repeated until fluid was clear. I did this over a few days.
Thanks Joe! I'll give it a go. I'm patient... |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3887
Rob,
| jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194
I do the same work, but littlebit differently.
| kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 86
That's almost true, except that engine must be indeed running to flush the system completely. 4l new fluid is needed for that. And attention is needed not to let the fluid level in reservoir get too low while flushing, because with engine running the pump is moving this fluid really fast!
Thatwhy I didnt start the engine, to avoid get air in system. It suck oil really fast.
And I add that the inner diameter of the return hose is 10mm if someone is preparing for the job. |
| All times are GMT |
