Home > Technical (L322) > TD6 Gearbox, not changing Gear
daveturbo
My 2003 TD6 Vogue Autobox will not change into 4th and 5Th.I fitted the recon box from a running breaker as mine letgo and thought easier to buy another gearbox. after driving straight away it tries to change into 4th staggers a second then the trans failure message appears,i have changed the autobox oil and filter also the 4th5th solenoid and still the same . gearbox code says gear monitor 4 fault, the gearbox drives fantastic compared to my old box apart from the upper gears,when pulling away slowly it seams to move off in 2nd gear,can any one please help,was going to try and change the other solenoids tomorrow,many thanks people,Dave. Mercedes AMG w207
E class Cabriolet
Overfinch L322 4.4 tdv8
1987 sierra rs cosworth 3 door white.
1985 escort rs turbo series one.
1992 sierra sapphire 4x4 cosworth red
1993 sierra sapphire cosworth 4x4 silver
1993 sierra sapphire cosworth 4x4 white
1995 ducati 916sp.
Post #483230 11th Jul 2018 10:15pm
RRPhil
http://www.fullfatrr.com/forum/topic46898.html
Phil
Post #483232 11th Jul 2018 10:23pm
daveturbo
Autobox
cheers Phil makes sense,but the oil was like new and no filings at all in the oil or magnet,which i would have thought would be there if the shaft was broken. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #483239 11th Jul 2018 10:43pm
Discotigger
Did you replace the torque converter, or is it the original?
Is there any chance it could be with the Lock Up Clutch, as that engages between 4th and 5th gears?
Could be that it's causing a gearbox fault?
Post #483240 11th Jul 2018 10:58pm
daveturbo
autobox
The Torque Converter looked like its was a week old lol so used the one supplied with the replacement gearbox,the gearbox is so so smooth to my old unit but just wont change,what do you mean by clutch lock up is this a solenoid driven part ? Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #483254 12th Jul 2018 9:07am
daveturbo
autobox
Anymore advice please. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #483355 13th Jul 2018 11:18am
Discotigger
Sorry for the delay in replying, I've been away.
I believe the Lock Up Clutch is mechanical within the torque converter, don't know if there are any electronic solenoids in the box itself to activate it.
Have you tried changing gears manually to get 4th and 5th gears? If you put the gear lever into Sport mode then you can push the lever forward and backward to manually change up and down.
That may help to narrow down the problem.
Having read rrphil's posts, I would add that if the shaft has only unwound enough to stop the 4th-5th gear shifts, you wouldn't get any metal bits in the oil. RRPhil is an absolute expert/genius on these boxes, so I would go with his suggestion and look at the 'toilet paper' shaft. Thumbs Up
Post #483357 13th Jul 2018 11:31am
Bobthebuilder4470
Scotland 2002 Range Rover Vogue Td6 Zambezi Silver
My gearbox was the same was told it was a shaft inside the box so removed the box and replaced it with the box from an x5
A few modifications and it changes so sweet had to use my own valve body.
Anyway when I stripped the gearbox no broken shaft. it was the valve body that was at fault sent it off to valve bodies uk who fitted sonnax valves so still have my old box for when I need another.
I would remove the valve bodie and get it tested b4 you remove the box
Post #483457 14th Jul 2018 10:17pm
daveturbo
auto
Great thanks i will remove the valve body first and have it checked. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #483664 17th Jul 2018 7:44pm
