Home > Maintenance & Mods (L322) > What to do if your DPF is blocked...
Page 43 of 43 <123 ... 414243
Range Rover L322
No probs - welcome to the rabbithole.
Here are the fields I recommend you watch while driving - the main ones are:
1) DPF Soot Concentration.
2) Exhaust Gas Temp Bank 1 - Sensor 2. During a Regen this will go up to 630º-660º until soot drops to approximately 2-5 grams (inferred).
One of my guys noticed a correlation on corroded Ford parts
3) Number of Demanded Regens
4) Total Distance (same as your Car Mileage) - handy when you screenshot to graph or analyse it.
If you watch these while driving, you will soon get a handle on what your car is doing.
If it is hitting 1-3grams after unforced regens, the regen is working well. If it is getting to 5 or 6 grams the matrix may be corroded.
One of the guys I worked with works on a lot of Fords, Land Rovers and Range Rovers. He noticed there was a period in 2010-2012 where Ford manufactured parts (like our DPFs) have corroded more than usual. His rumour/theory is there was a period when the steel Ford was buying from China was substandard. My original DPF was rotten from the inside out which supports this, but it was also left standing after being used on a saltwater ford.
To go even further into the rabbithole - I replaced that DPF with new. But I sent that old DPF to someone on here who had bought a 4.4 with the DPF removed (the car wouldn't run). He is still, to my knowledge, using the old DPF I gave him, and his car runs fine.
Things that stop regens are:
Going under 37mph.
If you accelerate hard.
Ideally you want to be running steadily at 50-70mph without slowing down.
Here are some graphs of DPF performance/sooting and distance between regens. As you are German (or live in Germany) I am very confident of your methodical approach and ability to apply logic to this so I am happy to share it. Laughing
In the summer I do more short trips, but I also believe this provides strong evidence that the weather/temperature plays a significant factor in DPF performance.
 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #717415 5th May 2025 12:43am
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
Interesting that you should mention the ambient temperature. I've had a TDV6 for almost 2 years and being of a certain age I have monitored my regens using the Kot Kit.
In Winter my distance between regens was 250 to 300 miles but during Summer it drops to around 180. Same type of runs but different outside temps. Also experimented with premium fuels and additives which made no noticeable difference.
Post #717424 5th May 2025 8:38am
steve2347
United Kingdom 2012 Range Rover Vogue 4.4 V8 Santorini Black
Recently noticed that my 2012 4.4 TDV8 dpf was filling up quickly but assumed it was because I've only been taking short journeys recently, unfortunately.
Managed to get on the motorway the other day just as the yellow dpf light came on at 23.5g and within about 10-15 minutes the value was down to 4.5g. Came back home on the A roads which was about a 20-30 minutes journey and had a reading of ~8g, but I was sat in non-moving traffic for a part of it so thought that might be why.
Next time out I took it on some nice country roads at reasonable speeds that were about 12 miles or so away from home, and stopped for a few hours before taking the same route home. When I got home I checked the dpf and got a reading of 14.9g.
I've managed to read about 23 pages of this thread and various others, and just wanted to ask a couple of questions.
Firstly, I presume I am correct to be concerned at the rate this is filling?
Second, I decided to check the egr valve position (commanded and actual) via the gap iid and from the moment the engine starts they are at 15% and 11% respectively. Is that expected? I have read elsewhere that it's usually shut initially, but if the commanded position is open then would that indicate something unusual is happening?
I have limited mechanical experience but I am pretty practical. I'm more than willing to inspect the inlets and MAF sensor etc, but I won't have time to do so in the immediate future. I've bookmarked the various steps suggested in the parts of this thread regarding troubleshooting steps and I'll go through them when I can. However, I wondered if there is any data that I can collect with the iid for now as I've got a longer journey I need to take?
Post #717503 6th May 2025 5:51pm
Range Rover L322
Hardy,
By chance my L322 regenned earlier so I screenshotted it for you for reference so you can see what a good regen looks like. I have highlighted the important fields.
Notes:
1) I was in traffic for a while after it went through the trigger point 19.7grams so it demanded 2 regens (numbers 471 and 472).
2) It successfully regenned but you will note the Successful Regen field does not tick up. Do not use this field.
3) When you are figuring this out it is a good idea to keep this on the whole time. You will soon understand out what is going on (steve2347 this applies to you too!).
4) Noting the resolution on the pics is not ideal:
Top Row Left is DPF soot concentration - inferred.
2nd Row Left is Exhaust Gas Tem Bank 1 sensor 2 (goes up to 640º) The main temp guage you want.
3rd Row Left is Number of Demanded Regenerations This tells you when a regen is happening.
3rd Row Right is Number of Successsful Regenerations This field does not work.
. 2012 L322 4.4 TDV8 AB low mileage - a peach
Post #717510 6th May 2025 6:46pm
Range Rover L322
1) Your fill rate is not significantly out of the ordinary. I would not be concerned at the fill rate yet.
2) The EGR valve is monitored by sensors which will alert you if there is a fault — attempting to diagnose based purely on degree of valve opening and timing is unlikely to yield meaningful insight.
3) The fact that the DPF drops to 4.5 grams following a regeneration suggests the system is functioning correctly.
4) If you remain concerned, consider running the IIDTool while driving — this will give you real-time data and a better understanding of the system’s behaviour, helping to identify whether further investigation is warranted.
It's easy to overanalyse DPF function, as it’s not always intuitive — this often leads to chasing non-issues. I would recommend simply driving as normal and, if another “DPF Full” yellow warning appears, begin monitoring at that point.
Hope that helps!
Post #717512 6th May 2025 6:58pm
steve2347
That does help, thanks.
I'm often guilty of losing myself in rabbit holes, so if I can avoid looking for answers when there's nothing out of the ordinary then I will.
I will collect some data though, just for the sake of having it going forward to see if anything changes. I believe there was a subjective difference with the car when I drove it less often and on longer journeys, compared to the frequent short journeys as of late. Would have been interesting to have tracked that.
Thanks again Smile
Post #717515 6th May 2025 7:15pm
Spridget
Different engine Steve but some of my ramblings might be of interest.
I monitor and record all my regens (L405 TDV6}.
Regen is triggered at 18.8g of soot or 51%. They normally take about 9 minutes and if conditions are all ok the soot drops to between 2.8 and about 4.8g depending on driving conditions.
Soot build up is normally around 11 miles per gram or 3.5 miles per %.
My average miles between regens is 170 but it has been as low as 130 and as high as 300 with no logical explanation for the difference.
If you read the Now I'm a regen nerd thread there's loads of good stuff and I find the Kot kit most convenient for watching regens. I have a Gap tool but haven't tried it on regens yet.
I became obsessed with DPF valves for a while but as previously stated, if it isn't happy it'll tell you.
Good luck and Happy regens. Very Happy
Pete
Post #717516 6th May 2025 7:56pm
JAD
United Kingdom 2012 Range Rover Vogue TDV8 Epsom Green
I have the red Dpf full message and restricted performance. Is there anyone on the Wirral with a Gap tool that could help me out with a forced regen. My Icarsoft tool won’t complete either a new Dpf or forced regen cycle.
Post #720224 22nd Jun 2025 11:43pm
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Yep - I’ve got one you’re welcome to borrow. Only in Heswall, but don’t know if you can force a regen on the car it’s not coded to, or whether it just reads codes etc.
Palme your mobile and we can have a chat.
Cheers
Jonny
Post #720379 25th Jun 2025 9:29pm
