![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 new battery |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Hi Folks,
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
Also I do think AGM is recommended, which 019 did you get?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Ah the battery swapping joys.....
https://www.halfords.com/motoring/bulbs-bl...tsid:94971|cid:1034356518|agid:51236243896| Current: 2011 FFRR Vogue SE 4.4 TDV8
Still wouldn't work with the lugs off, there's no room for the +ve terminal connector!!!
The 019 is the one suggested by the Halfords website, complete with 5 year warranty.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7966 ![]() ![]() ![]() |
Think you need a diagnostic tool or a friendly garage. Charging system needs to do different things I believe or battery life will be substantially shortened.
Will reset it in the morning, thanks all for pointing it out |
Bushy that link you posted isn't AGM....
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3853 ![]() ![]() ![]() |
I swapped mine for one of these a couple of months ago and , touch wood, it seems OK.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
bit cheaper than the £226 JLR battery i 'had' to get when my westie wouldnt start on the first day of my holiday .. |
Stan,
Thanks for all the input chaps -- now I'm happy to be shot down, but with a 5 year guarantee and the fact that the Yuasa was the one they suggested when I entered my 'reg' will this not be OK -- I mean it's a battery, not likely to die over night, and if it begins to fail I'm likely to notice? My, I suspect original, battery as fitted gave me about 3 weeks notice it wasn't happy................. Current: 2011 FFRR Vogue SE 4.4 TDV8
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
It'll be OK. I've had the same Yuasa 019 fitted for the past year and it's been fine. |
