![]() | Home > Technical (L322) > Replacing the wiper mechanism. |
Danbhardy Member Since: 10 Nov 2018 Location: Chorley Posts: 44 ![]() ![]() ![]() |
Has no-one done this? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
if you mean the front wiper mechanism then this is the first i've heard of it breaking...i might be wrong so do a search .. |
JWL Member Since: 07 Aug 2016 Location: North Wales Posts: 42 ![]() ![]() |
Must be the time of year |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
If it's the linkage arm it depends if it's actually broken or just dropped off the knuckle, if it's intact you can swap it so opposite ends are now on the knuckles. Did mine 12 months ago. 2011 (MY12) 4.4 TDV8 Vogue
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 359 ![]() ![]() ![]() |
Hope this helps you Fella Did both our cars last summer ( just in case ready for winter ) - takes about 1 hour. You do need to puller to take off the wiper blade arms - when you re install INSURE YOU PUT GREASE ON THE TREADS - LR factory did not put grease on the spindles - Aluminum & Steel will bind over time ! Take your time when putting the wiper arms back on - threads are thin and you can strip them if your not careful. The cars are 12 year plates and wipers are so important - especially in the winter - its worth replacing these every 5 years before they pack up - don't want them packing up on a airport run !
