Home > Technical (L322) > Heeeeeeelp ! |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
when you clear the faults do you hear the pump start to run ?
16th Jan 2019 8:47pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 799 |
I do if I do the steering reset , yes
16th Jan 2019 8:51pm |
tony66 Member Since: 30 Nov 2014 Location: fife Posts: 92 |
check its not stuck on transport mode or something daft like that-also that the height sensor actuator arms have not inverted themselves giving weird readings |
16th Jan 2019 9:05pm |
when I got it 2 years ago its was stuck in transport mode , ive checked all the arms are moving well etc pal so that rules them out but how do it get it out of / check wether it is stuck ?? |
16th Jan 2019 9:07pm |
it all depends if you are using the solus pro,bmw inpa etc as to where you find it on the menu tbh
16th Jan 2019 9:57pm |
Ok so was that on the bmw X5 on solus pal ? Cant remember seeing it in the LR program , i have INPA so can look on there if neccessary
16th Jan 2019 10:05pm |
Another update , using delphi on the bmw X5 programme , i have the options of activating all suspension bits and turning off transport mode so that is good news , however the compressor isnt kicking in , the fuse in the boot had blown , i replaced but still nothing , if i activate say , the front strut i can hear faint clicks n wurs so its looking like ive goosed the compressor while testing it yesterday , opinions guys ?? |
17th Jan 2019 5:39pm |
so was it stuck in transport mode? |
17th Jan 2019 5:54pm |
I cant say for sure with the compressor not working , couple of can codes to delete but they never returned , as i said above , activate any part and i can hear things working so that suggests that its not but i did start by removing transport mode |
17th Jan 2019 6:07pm |
should be simply sorted once you fix the compressor-they seem a bit fragile if you ask them to do too much graft... |
18th Jan 2019 12:18am |
What can i do to be 100% sure the comp is goosed ?? |
18th Jan 2019 8:41am |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 |
I had this exact same problem. Dont panic, nothing is broken at all.
18th Jan 2019 8:49am |
As i said earlier pal , the comp isnt responding to any activation i try so i need to check the comp to be sure before looking at other possible causes , i have bo faukt codes either
18th Jan 2019 8:53am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6397 |
Try powering the compressor directly from a battery .
18th Jan 2019 10:19am |
