![]() | Home > Maintenance & Mods (L322) > Servicing rear brake calipers 2011 model |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3869 ![]() ![]() ![]() |
I have been searching for a thread that might help me strip down, clean and free up my rear brake calipers, but not found a good βhow to β guide.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
Just so your aware, both cars above have completely different types of rear callipers...
Thanks Craig |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
Cheers Craig, Probably best to obtain a new caliper. Considering the effort / cleaning I went through last time. |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Mike, if you are changing only rear pads and not rear disks you will not be touching EPB. changed mine rear pads this spring and it is straightforward job. |
Thanks Nino,
yes I have. used Textar brake lube. can't remember when squeezing pistons in if it is necessary to twist them at the same time. 2012 TDV8 Black Edition
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
I think the pistons just press in.
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
I've just had to replace both of my rears. One of them seized completely (bit irritating as I had just had the disks and pads replaced and they were apparently fine then as 'they know what to look out for') and I had the other one replaced as a precaution.
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 358 ![]() ![]() ![]() |
best wishes Fella
Thanks,
Baltic Blue
One thing missed on that video would be to pull the sliders out of the calliper bracket clean them & refit using the appropriate grease... I would also grease the disc securing bolt... And finally, if your going to that much trouble, why not paint the outside of the disc? He's clearly painted the bells, why not the outer edge?
It was Thomas Cook flight this year, but we usually use Jet2 .
