Home > Technical (L322) > LR029140 coolant hose 4.4 TDV8
edward19
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
Hi
I've managed to snap off the thin plastic pipe of my coolant hose LR029140 on our 4.4 TDV8. Does anyone have one of these they don't need and are selling cheap as I only need a bit of it.
Thanks
Post #505959 21st Feb 2019 10:01pm
GGDR
It's an easy one to snap, quite a few people have repaired theirs with a stent.
. Cheers, Greg
Post #505962 21st Feb 2019 10:21pm
edward19
I tried fixing it with some glue and that lasted less than 5 seconds. It's about £85 for the new pipe and I only want that plastic bit. I might have to bit the bullet but will only change the little bit I need and not faff about with the other pipes.
Thanks
Post #505965 21st Feb 2019 10:28pm
rjff
There is a repair posted on here by, IIRC, by JCW. As GGDR says, it's a stent repair.
https://www.fullfatrr.com/forum/topic48509.html?highlight=stent
If you need a new part it's £80+ and I suspect anyone here will keep the bit if they have it as a safeguard. Cheers
Richard
Gap IIDBT
Post #505967 21st Feb 2019 10:30pm
edward19
That's great. i'm going to have a go at that. Out of interest I've looked on ebay for a female to female coax connector but cant find one. Is it a hard to find bit?
Post #505969 21st Feb 2019 10:39pm
edward19
Found it, so it's called an F type connector.!!!
Post #505970 21st Feb 2019 10:43pm
rjff
Let us know how you get on. A repair like that which saves some plastic pounds for other things is welcome Very Happy Cheers
Richard
Gap IIDBT
Post #505971 21st Feb 2019 10:48pm
edward19
I've just ordered a connector from ebay. 99p delivered, great. My sort of price range.!!! Will report back once I've done it. Getting the blasted thing to even run was a mission but it sounds pretty good for 143K!!!!
Post #505973 21st Feb 2019 10:56pm
