![]() | Home > Technical (L322) > 4.4 TDV8 engine shut off on motorway |
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 222 ![]() ![]() ![]() |
Had a bit of a scary moment today. I was cruising at about 70mph on the German Autobahn in the second lane when the engine suddenly shut off and took the power steering and electrics (at least all internal displays) with it. I managed to thread the car between two articulated lorries and roll onto the hard shoulder. The hazard lights still worked.
According to the dealer none of the error codes were related to the issue. They detected that the fuel filter was causing insufficient fuel pressure to the engine so the filter was replaced (last replacement was just over 18 months ago). They also regenerated the particle filter. They sure used a lot of fuel to do that. It went in with over 3/4 of a tank and came out with just under half... 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
hi mate, not sure if this relates to your much newer vehicle, but I had a similar issue, which after a bit of digging turned out to be the XYZ switch losing connection and turning the engine off. The short term fix was to move the gear selector back and forth enabling the car to start and drive off again.
Not sure about the switch. The selector itself is the rotary variety that raises up when you switch the engine on. However, once the engine is switched off it lowers into the center console so you don't have the option to move it back and forth. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
