Home > Technical (L322) > Engine don't start now
Page 1 of 4 1234>
Cheapscaff
United Kingdom 2004 Range Rover Vogue 4.4 V8 Bonatti Grey
Hi all I've just done some work on the drivers seat trim switch panel which involved disconnecting
the power supply at the switches. It's all back together now. But the engine won't start and the steering coloum is going up and down I have connected if correctly and I have tried the usual disconnecting the battery but to no avail. Tia
Post #510519 1st Apr 2019 3:03pm
disconnect the seat power leave for 30 minutes letting everything power down, and then see if it starts..
Post #510520 1st Apr 2019 3:24pm
Cheapscaff
Hi Stan thanks for your help. I did that and it's still not starting could it be I need to reset the fuel cut off valve I've not managed to find it yet,failing that maybe easy start spray case the fuel pump has died. If it starts then could be new pump.
Tia
Post #510536 1st Apr 2019 5:45pm
Cheapscaff
Forgot to mention the steering is ok Now I notice when trying to start the key will spring back as when stoping the start process but the starter is still engaged. I have to turn the ignition off. I now wish I had disconnected the battery before starting the seat project.
Post #510538 1st Apr 2019 6:00pm
Weegie
If I understand you correctly, it sounds as if the starter pinion is sticking in the engaged position. If that is the case, it would mean removing the starter to ensure the pinion is free to recoil or, possibly, a new starter motor. John
GAP iiD BT-Sold
Post #510539 1st Apr 2019 6:05pm
ur20v
A Trap
How is your battery? If it has run down below 12.5v it will play havoc with the electrical systems
Post #510540 1st Apr 2019 6:05pm
Cheapscaff
hi the battery is/was fully charged I'm hoping if I can sort out the non starting issue it might sort the starter out on start up.
Post #510542 1st Apr 2019 6:24pm
Cheapscaff
Hi all Can anyone pinpoint the location of the inertia cut out reset button. Tomorrow I'm going to check if I have a spark by removing a spark plug an coil. Also if I have fuel pressure at the shreader valve on the top of engine and power to fuel
pump/fuse/relay. I suppose it could just be just coincidental that I was working on seat electrics and the fuel pump is packed up.
Post #510557 1st Apr 2019 8:25pm
holidaychicken
Does thevengine crank but not fire or it won’t turn over at all?
Post #510593 2nd Apr 2019 1:46am
Cheapscaff
Hi thanks for your time. The engine cranks over fine it just don't fire up. I'm going out to pull it to bits now.
Post #510614 2nd Apr 2019 9:56am
Tugger
United Kingdom 2009 Range Rover Westminster TDV8 Stornoway Grey
If it's turning over but not catching, it could be lack of fuel. If there's nothing coming out of the schrader valve, have a look under the rear seats - you'll find the tank access hatches - the low pressure pump is in the tank on the right hand side so check for power there.
Could it be something as simple as a blown fuse on the fuel pump circuit?
Do you have a code reader, or access to one just to see if there's any faults registered? When I had fuel pump issues there were a few "low fuel pressure" errors on the diags.
 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Nissan X Trail 1.6TDCi Tekna
Fiat 500 1.2
Post #510619 2nd Apr 2019 10:22am
Cheapscaff
Hi thanks for your help. I have checked the pump fuse that's ok if I bypass the relay the pump works ok if I replace the relay the pump won't work I have put the heated seat relay (same numbers) in and it don't work. Is there a way to bench test a relay. I have removed the fuel pump unit from the tank already? Tia
Post #510684 2nd Apr 2019 5:31pm
https://www.wikihow.com/Test-a-Relay .
Post #510692 2nd Apr 2019 5:52pm
Tugger
Have you tested the fuel pump relay in the connection for the seat relay (assuming they really are the same) - that'll tell you if it's the relay or the connection to it 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Fiat 500 1.2
Post #510710 2nd Apr 2019 7:34pm
Cheapscaff
Hi yes I tried that and it was ok. Where I'm at now is I've checked the relays are working. I have found that when checking the power supply at the relay insert holes they are all correct with ignition on/ off im using hole 86 as ground.
When I put the relay in it doesn't energise to make the necessary contact. The power is there but no ground? But I know this ground is good as I use it to check for power. If I push i wire in 86 (ground) with the relay blade and manually ground it.
Turn on the ignition and the pumps working. So any ideas where to look next. Does this sound like an ecu issue. Also could this be the same issue with the starter continuing to crank when I let go of the key. Tia
Post #510719 2nd Apr 2019 8:14pm
Page 1 of 4 1234>
