Home > Technical (L322) > 2012 TDV8 Air Con issues, looking for help and advice |
RCV ? .
12th Apr 2019 7:27pm |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 391 |
Refrigerant Control Valve.
12th Apr 2019 7:37pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7634 |
Yeah, it’s that valve. Mine takes a while to blow cold sometimes....
12th Apr 2019 9:31pm |
Obvious things first, but check the control wheel on the centre vents is set to blue... There is nothing that can't be fixed with a hammer😜😜
13th Apr 2019 8:37pm |
Totally agree, northernmonkeyjones, I did that 😁
13th Apr 2019 8:42pm |
Unlikely, my obd tool tells me nothing most of the time..... There is nothing that can't be fixed with a hammer😜😜
13th Apr 2019 9:02pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
Does your AC shop check everything works before gassing? Here in the UK they have to as its illegal to fill an untested system as it could leak into the environment!
13th Apr 2019 9:19pm |
