Home > Technical (L322) > Intermittently stuck in Park
Skeletor
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Java Black
Seem to have an intermittent issue normally first thing in the morning, can’t get the selector out of park, pressing the brake you can hear a little click by the stick but still won’t move, try it a couple times either works or turn the engine off and back on it will go. What stops the gearbox going out of park?
Thanks
2009 5.0 S/C
Post #512046 14th Apr 2019 1:06pm
Have a check on your gear selector rod alongside the gearbox. These can seize, come loose etc. If forced, rod can bend as well! .
Post #512051 14th Apr 2019 1:39pm
Skeletor
It will move and then be fine all day, then intermittently it just won’t budge. Seems like there is something electronic stopping it moving
Post #512062 14th Apr 2019 4:12pm
