Home > Maintenance & Mods (L322) > Air con
Peopete
Air con
My air con is not very cold would a regas sort it or could it be something else.
Post #512559 19th Apr 2019 8:52am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
First thing is to find out why you have no gas possible leak on the evaporator maybe?
Post #512591 19th Apr 2019 4:46pm
Peopete
Could be a prosses of illimination then first.
Post #512596 19th Apr 2019 5:19pm
If you take your car to somewhere that recharges ac systems as part of the process they will evacuate the existing gas and oil and then carry out a vacuum test. Only if the vacuum test is satisfactory will they recharge the system. If you have a leak thy will tell you. Thumbs Up
Post #512600 19th Apr 2019 5:46pm
Peopete
Thanks for that advice mate, I will do that👍
Post #512607 19th Apr 2019 7:06pm
