Home > Technical (L322) > Danger - anyone else had a tow bar detach mid journey?
Just heard a horror story from a mate about when his swan neck tow bar suddenly detached from the socket while he was towing his car trailer. Caused a bit of third party damage and wrote off the trailer. The obvious retort was that he hadn't had the lock wheel properly returned to the green and/or the key not locked. But he's very experienced with this and knows it was. Post accident the swan neck has been examined and it no longer needs the key to allow the release knob/wheel to turn. He's had some engineers look into it and it seems there's a weakness with the design. As it sits quite low, its possible to ground out the tow bar in some circumstances and that can dig the lock wheel prongs into the road surface and turn the wheel which will obviously cause it to release from the socket. So this post has three purposes:
1 To make us all aware of a potential danger with the design and be particularly careful and vigilant on any surface where grounding out may happen.
2 Apparently there was a recall many years ago on the original swan neck although that wouldn't apply here as the tow bar was only fitted in 2017 to a 2012 car. Anyone know what that earlier recall was about?
3 To ask if anyone has had a similar experience ? Has anyone here ever had the swan neck detach when it shouldn't?
Thanks... Mike - MPx
Post #521022 7th Jul 2019 11:01pm
AJGalaxy2012
I believe there are a couple of types of detachable towball used by Land Rover. One i believe was LR's own make and was subject to a recall, it suffered premature wear and became a loose fit in the receiver. On mine it has the Westfalia one, the same design I used for years on my Touareg and doesn't have any such issues.
As far as grounding goes it would have to be a pretty dire landscape to ground it out.
This is the one with the issue
A lot of discussion on the caravan forums about it
https://www.caravantalk.co.uk/community/to.../#comments
[/url] BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #521031 8th Jul 2019 5:57am
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
Yep that was the disco/rrs one the plugs into the rear crossmember directly and when left in it could rattle about and make the hole too big so the unit could come out.
Back to the op, what was his nose weight as if you put a vehicle on a trailer in the wrong place it could increase it possibly to beyond the limit.
Never liked land rovers L322 removable hitch design so I got the westfalia one which looks better when not connected as it plugs directly into the 2inch receiver, has a drop plate hitch on it and secures with a pin and clip. It does make a bit of noise with no nose weight but very quick and easy to attach and detach. Doesn’t fit in the little hitch cubby though and it is quite heavy. Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #521033 8th Jul 2019 7:54am
OK thanks. I've never seen that LR one before, only ever had the Westfalia swan neck on any of mine which is what John had too so its really their one that we are interested in.
Cant categorically say about the nose weight as no tool was used, but the same technique (see that the trailer is sitting level and moves up with a tug on the hitch) that has been used across many years and 14 (!) Range Rovers.
I like the idea of the one that fits the 2" receiver - is that what some refer to as the farmers hitch? I've had a quick look on the Westfalia site and cant see it (although I did find a picture of it on here in another thread) do you have a part number by any chance? And is it LR approved? Mike - MPx
Post #521042 8th Jul 2019 9:57am
ianmacd
I got mine from pf jones as a complete fitted solution (for my last 2 L322's) but this looks to be just the hitch for the 2inch receiver.
https://www.pfjones.co.uk/landrover-range-...-only.html
You would need the pin too I would guess. Mine both had a little bag to keep the hitch in when not in use. Current: RR L322 2010
Post #521043 8th Jul 2019 10:02am
Hmmm thanks again...but not sure that would work with mine as I've got the late body kit which looks like it may come too low and too far back. Mike - MPx
Post #521046 8th Jul 2019 10:14am
ianmacd
Works with my 2012 AB Current: RR L322 2010
Post #521048 8th Jul 2019 10:18am
Interesting...do you have the extended body kit on yours?
 Mike - MPx
Post #521051 8th Jul 2019 10:48am
ianmacd
Would appear not
Post #521057 8th Jul 2019 11:13am
p38arover
Australia
I guess that problem won't happen here in Oz, we use this type of towbar tongue (this is mine).
 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #521060 8th Jul 2019 12:17pm
TJH1985
Farmers Hitch here Mr. Green it’s agricultural and can’t be noisy even with a perfect nose weight but it’s very secure, and when not fitted with the bung in the receiver the car looks great 👍
Post #521061 8th Jul 2019 12:22pm
Weegie
@P38. How do you get on with different trailer heights? John
GAP iiD BT-Sold
Post #521062 8th Jul 2019 12:23pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
same here, I went for the farmers hitch because removed it looks less intrusive than the westfalia swan neck one. I got mine from pf jones also. my only concern is that some scroat could unpin the trailer very easily, so if I'm leaving the car and trailer I tend to padlock the two together.
Post #521080 8th Jul 2019 4:32pm
It’s the same system in the US - you can buy hitches with different amounts of ‘drop’, so you get the right one for your vehicle / trailer combo
Post #521090 8th Jul 2019 5:42pm
Weegie
Thumbs Up John
GAP iiD BT-Sold
Post #521101 8th Jul 2019 6:28pm
