Home > Maintenance & Mods (L322) > Brembo Caliper Pins! |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16165 |
A 22mm socket and a breaker bar is what you'll need sir |
7th Jul 2019 11:51pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
bolts are 21mm 12 point, use some Loctite when reinstalling. if you polish pins and applied some nano coating it will prevent them from sticking. 2012 TDV8 Black Edition
8th Jul 2019 8:35am |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 701 |
used copperslip on the pins/retaining pin holes
8th Jul 2019 9:08am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1688 |
No, copper grease will react with the aluminium caliper, and corrode
8th Jul 2019 10:14am |
use aluminum or nickel paste.
8th Jul 2019 2:52pm |
