![]() | Home > Maintenance & Mods (L405) > running wire from cab to engine bay |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35871 ![]() ![]() |
as above , any thoughts on how to do this? ... - .- -.
i'm pretty brave Alistair |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8134 ![]() ![]() ![]() |
Bulkhead looked pretty inaccessible to me |
agreed...theres to much stuff in the way.... ... - .- -.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883 ![]() ![]() ![]() |
Does the air box for the pollen filter come out easily, in a similar way to the L322 ?…… it might reveal an existing grommet hole ?
not sure Mike...that would bring it out around the top or behind the head unit.. ... - .- -.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988 ![]() ![]() ![]() |
If what you are wiring is only for the duration of you owning the car it's usually possible to get the cable to the front passenger door opening from the engine bay and then tape the cable to the body above the top hinge, lift the inner door seal and run the cable over the seal mounting flange and into the car that way.
i think thats the same as Alistair's suggestion ..i reckon that will be the best way to do this, thanks.. ... - .- -.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1587 ![]() ![]() |
Does the L405 differ from the L322 insomuch as access from the engine bay?
its a lot different..the battery is in the boot for a start and there doesnt seem to be any obvious route's into the cabin... ... - .- -.
Thanks Stan Ron B. VK2OTC
thanks for all your suggestions, i've gone the door pillar/trim route....dont look to bad |
Hard to give you marks out of 10 without the photos...... |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 ![]() ![]() ![]() |
What about near the steering wheel connection into the cabin it seems to run through a rubber boot through the bulkhead you might be able to squeeze it through that way ! |
