Home > Maintenance & Mods (L322) > Slight front end knock
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
So over the last couple of weeks I've had a slight front end knock. More of a feel than an actual knock so booked in with my local garage , who I must say is so far has been brill .
Any way when he checked it was very slight track rod end play on the near side , so I told him just replace it .
But the problem he encountered was he couldn't release the track rod end from the track rod inner as it was seized solid ,he rang me and I said just replace the lot , when I went to collect my FF he showed me the old part where he had to cut and heat to get the outer cover off , all done now but it's booked in on Monday to get the other side done although there's not play it's in the same heavily rusted condition and also for a new bottom arm as there is very slight play there although he said it's almost undectable , so just an update if you going to get your tracking done just to make sure all is unseized or renewed otherwise your wasting your time as the tracking will not get done and many out there will say it is . My mechanic is going to loosen off and anti seize all my tracking components prior to going for 4wheel tracking next week .
All that said my drive home felt great
Cheers henda Thumbs Up
Post #528963 24th Sep 2019 8:23pm
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
I’ve just had my track rod ends done and encountered the exact same problem. The inners were so cheap it made sense to do the lot
Post #528974 24th Sep 2019 9:14pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
Re: Slight front end knock
I have got exactly the same problem with my track rod ends. You will probably find that the adjusters on the rear suspension are seized up too.
Post #528991 24th Sep 2019 10:17pm
Henda
Rear end is the next job unless my fitter says he's freed them and anti seized greased them Thumbs Up
Post #529224 26th Sep 2019 10:17pm
Sandyt
I just replaced the rears and they were solid did the fronts a few weeks ago due to wear inner and outer when I took the nearside inner out it was cross threaded - I have had the vehicle since 60k miles now on 185k so guess it came out the factory like that mmmm
Post #529238 27th Sep 2019 12:14am
Henda
Well all good now new o/s lower arm full new inner/ outer track rod on both sides 4 wheel tracking done , FF feels kind of stable and positive on the road now all done and came in under £300 inc tracking Thumbs Up
Post #529741 1st Oct 2019 7:52pm
