![]() | Home > Technical (L322) > Selecting Access height |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 640 ![]() ![]() ![]() |
It drops a couple of inches and movement is obvious when I park mine up with headlights on against a wall, but not that noticeable when just out in the open. What you can see is the lowering tell tale on the console flashing and then the access height light up once done. Obviously all movement stops if someone opens a door... Mike - MPx
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547 ![]() ![]() ![]() |
Definitely should be a noticeable difference. If you're concerned, just take a tape measure and check the distance between the centre of a wheel and the bottom of the wheel arch? 2016 Skoda Octavia VRS Estate
Clubman Member Since: 18 Sep 2019 Location: Barreiro Posts: 33 ![]() ![]() ![]() |
I think I will, I might just be me being paranoid, but is my hard earned €€€ on the line !
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
I used that for dogs last weekend but it sank much less then my previous FF 's.
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
You should feel it drop for sure.
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
With the GAP tool you can change the heights. |
