![]() | Home > Technical (L322) > Coolant leak 4.4tdv8 |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2626 ![]() ![]() |
Oil cooler gaskets, at the back of the vee. |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
So does engine coolant go through the oil cooler then?
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
It certainly does.
Yeah, DrRob informed me about that mine looks to be ok. Regards
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 948 ![]() ![]() |
If it’s your oil cooler gasket you’ll see an oily film in the expansion tank - or worse obvious signs of oil floating on the surface if you remove the cap. |
Didn’t notice any oil film when I topped it up yesterday. Regards
SO No coolant leak found with a pressure test and no signs of a leak...
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
You are losing oil and coolant. My money (£5 |
Well the dealer is stripping the car to get to the v to look at oile cooler and i think they said egr cooler also? Line was a really bad signal
Keep us posted |
Grab a beer... |
