Home > Maintenance & Mods (L322) > TD6 - any way to test servotronic valve
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
As above, got a feeling my Servotronic valve is playing up, usual symptoms heavy streering at low speeds etc. Is there a way of testing it? Or is it a case of replace, and hope it cures it?
Post #531106 16th Oct 2019 2:42pm
you could disconnect it and see if that makes any difference.. ... - .- -.
Post #531113 16th Oct 2019 3:04pm
mrblonde
Thanks Stan
Sorry to sound a bit, well, blonde... Will it be obvious as to what it is when i look under the front wheel arch?
Post #531208 17th Oct 2019 11:35am
many years since i did mine but from memory its behind the wheel arch plastic on the off side front.. ... - .- -.
Post #531213 17th Oct 2019 12:03pm
mrblonde
Cheers Stan, will wait for the downpour to ease and climb under there this weekend with a bit of luck Thumbs Up
Post #531225 17th Oct 2019 2:23pm
Pawl
Follow the track rod end inboard & you'll see it in front & above the driveshaft (you'll need the wheel off)
The connector needs to be depressed to disengage it before pulling off carefully (it can be broken !) Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #531239 17th Oct 2019 3:44pm
Welshdragon
Have you checked the uj's on the steering?
mine was getting really bad the other week and I too thought the valve was the cause.
After search on here and read a good thread where some one changed all, from the rack to the valve and still made no difference then checked the us's......it was this all along so got my mechanic when doing my FF MOT to check it out.....and low and behold, lower uj was the issue.
Worth looking at that before hand. If it dont work.......burn it!
Post #531310 18th Oct 2019 12:15pm
