Home > Maintenance & Mods (L405) > L405 Roof bars recommendations with no rails
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
Hi everyone,
I do not have roof rails on my L405 and I feel like the roof rails plus roof bars will raise the basket I want to fit far to high and there will be a notable gap between the roof and the base of the expidition basket.
So I am on the hunt for roof bars that are slick enough to fit with no rails on the car, has anyone ever used any of the available universal ones that fit in the door shuts etc.?
Failing that i will have to make my own custom brackets and maybe take off the rail finishers and bolt directly to the roof
Post #532313 27th Oct 2019 6:03pm
Baltic Blue
I have got a pair of Thule roof bars for my L322 that fit in the door openings and then pull down on suction feet.
I can’t really see why they wouldn’t fit equally well on a L405, but someone may know better ?
Post #532316 27th Oct 2019 6:13pm
Thule don't list any.
Not sure if the L322 ones would work with anything significant on the roof.....
https://www.fullfatrr.com/forum/topic52226.html
Post #532318 27th Oct 2019 6:18pm
palli
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
I queried with Thule why there were no roof bars for my vehicle. Their reply is below
"Good morning, thank you for taking the time to contact Thule with your enquiry.
Based on the vehicle details that you have kindly supplied I have checked our guides, however I have found the vehicle appears on our 'No Fit' list for roof mounted racks.
The Chief Test Engineer noted at the time of testing that this was due to the profile of your raised rails on the roof of the vehicle not allowing the solutions to attach safely and securely.
The only solution that Thule manufacture for your vehicle would be a tow bar solution.
Perhaps contacting Land Rover customer services to see if they have over come these difficulties."
JLR CS point you to their roof bars in the accessory list 2008 Vogue Black - gone
2012 Vogue SE White - gone
2016 Autobiography Blue - gone
2019 Autobiography Grey - gone
2020 SVAutobiography Red
Post #532359 27th Oct 2019 10:48pm
Charles89
https://rover.ebay.com/rover/0/0/0?mpre=ht...2737714488
This is the style I'm after.
On another topic perhaps, I am looking to go whole hog and have a winch and snorkle, but the issue is the SDV8 has 2 intake boxes and snorkles are available for the 3.0TDI but not the V8 I'm trying to best replicate the Silk trail 2013 L405, but so far no companies offer a step winch impact bar to sit behind the bumper etc. So I suspect most of it will be a bespoke build and i will have to get my welder out and make one from plate steel
Post #532388 28th Oct 2019 7:35am
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
I had this exact same problem with my 405. I spent a load of cash on the OEM roof rails to then fit cross bars.
I wouldn’t buy the rails again, they’re absolutely hopeless! Both a useless design and they appear to be made of cheese Evil or Very Mad They do look good if left untouched though Thumbs Up
Post #532390 28th Oct 2019 7:59am
Charles89
Thanks that is very useful to know indeed!
Given that the bolt holes are present underneath the trim blanking strip I would imagine I would be able to design and build my own that bolts directly to the runners using the OEM fixing for the rails etc.
Post #532398 28th Oct 2019 9:22am
Seems reasonable that you could design & fabricate something to use the mountings for the rails.
The only concern would be insurance liability should anything go wrong - hopefully it wouldn't, but worth bearing in mind.
Post #532403 28th Oct 2019 9:58am
Also, if you're doing a full build, then be sure to post up a dedicated thread like the one Haylands did for his Thumbs Up
Post #532408 28th Oct 2019 10:52am
For my L322 I made up some roof bars out of galvanised unistrut on purpose made mounting blocks that screw into the roof fixings without having to break off the fixing cover flaps.
Could carry a tank on them Thumbs Up
Post #532411 28th Oct 2019 11:13am
pherplexed
United States
Charles89 - I've got the factory roof rails and have successfully fitted Thule crossbars and a Rhino Rack platform/basket...overall, a very low profile setup.
I used the Thule 450R Rapid Crossroad mounts (that's the US model number...not sure if that's universal) and they fit the factory roof rails just fine. I think Thule does not officially list support for the L405 b/c it is a bit of a tight squeeze fitting the rubberized metal band under the rail. But it fits and works perfectly.
The only downside: the setup is actually so low profile, the panoramic sunroof can only open when the bars are in a few vary specific locations. I have mine placed so that I can use the sunroof fully (even with my bike trays mounted)...but not with the rhino rack.
 2021 P525 | Eiger Gray
Post #532476 28th Oct 2019 5:52pm
Charles89
Thank you for taking the time to share, that is much appreciated Thumbs Up
Do you think your set up would comfortably take 150kg? I'm not sure what the over all weight limit is for the L405 roof rails?
Post #532492 28th Oct 2019 8:28pm
The official rating is usually limited by what you could happily do a slalom course with - and is governed by vehicle dynamics as much as anything else.
When parked up, I'd expect it to be able to take a roof tent with a couple of people......
Post #532493 28th Oct 2019 8:42pm
pherplexed
United States
What Alistair said. LR say the max load for the SWB roof rails is about 100kg, but that seems low to me. 2021 P525 | Eiger Gray
Post #532555 29th Oct 2019 3:51pm
PaintHorseOne
United States
Wondering if anyone has considered the EZ-Awn Roof Rack Rail set. https://www.equipt1.com/collections/roof-r...-rack-rail
Seems like it "might" be an option over the OEM raised rails?
PH1
Post #535460 26th Nov 2019 12:04am
