![]() | Home > Maintenance & Mods (L322) > Caravan wiring |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 822 ![]() ![]() ![]() |
is it one of these
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 700 ![]() ![]() ![]() |
The grey one is normally to power the fridge while on the move & also to run a live charging wire to the 12v system on the caravan. You would need a couple of live wires from a reliable source & an earth. It is 'do-able' but............
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 180 ![]() ![]() ![]() |
If you convert a 7 pin plug to a 13 pin plug, it becomes a MOT testable item I believe, whereas a 7 pin isn't
I'd heard that towbars were part of the test but I hadn't heard of the electrics.
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
Personally, I would buy a "vehicle specific" electric kit which may very well be plug and play.
Just done a google search and...…
steve1 Member Since: 29 Jan 2018 Location: manchester Posts: 56 ![]() ![]() ![]() |
Many thanks for your advice |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 189 ![]() ![]() ![]() |
