Home > Maintenance & Mods (L322) > Handbrake cable bolt |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 |
Are you talking about the EPB cable to brake backing plate screw?
18th Nov 2019 8:54pm |
No EPB on an '02 .
18th Nov 2019 8:55pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
On about my 07
18th Nov 2019 10:19pm |
nice first post edit
18th Nov 2019 11:19pm |
Moulded end of the outer cable that allows the cable to be attached to the brake backing plate and also prevents the whole cable from being pulled through when applying the EPB. The screw/bolt does go through it in about the 9 o'clock position. |
19th Nov 2019 8:54am |
Ok great - anyone know about the bolt is it an m6? Current stable:
20th Nov 2019 9:23pm |
M6 10mm Torx
21st Nov 2019 8:57am |
thank you Current stable:
25th Nov 2019 4:37pm |
