![]() | Home > Maintenance & Mods (L322) > IID tool flattened my battery |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
After uploading some new settings last night, I turned off the car and locked it, forgetting to unplug the IID tool.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
IID manual states an external power source should be connected when CCF editing etc.
I didn’t know this.
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 541 ![]() ![]() ![]() |
CCF editing / module programming draws a lot of current and you should have a stable, external supply connected. Another option is to connect to another running vehicle via jump leads. I'm not sure that's recommended though...
Ent Member Since: 20 Oct 2014 Location: Preston Posts: 42 ![]() ![]() ![]() |
Learnt this pretty early on the D4, the problem isn’t how much the IID tool draws its the fact your car doesn’t go to sleep that’s the issue. |
Download manual on IID website. It's not the easiest to negotiate but give it some time Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 339 ![]() ![]() |
The IIDTool draws charge when the ignition is off.
I had to get the RAC out to start the car. It was on 7 volts when he connected his jump leads. It took his boost pack and his van to get it started.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Andy,
Page 56 of the manual might help? Pretty sure Pat at GAP will advise the same.
I don’t leave it permanently connected. This was accidental. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
