Home > Technical (L322) > Restricted Performance - what is this fault code pointing to
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
Hi all
Car come up with the restricted performance on my way back today. Tried switching on and off but it come back. Read with the tool and it come up with this? Any idea what this is suggesting?
Post #537293 13th Dec 2019 5:20pm
M@r]{
Oh and when I clear the fault, it comes straight back again. When I click the “i” I get this info.....
Post #537295 13th Dec 2019 5:22pm
Spud
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
https://www.fullfatrr.com/forum/topic50202.html?highlight=p040d 2006 4.2 SC
Post #537307 13th Dec 2019 7:13pm
M@r]{
Wasn’t 100% sure that code was the cause of my
Restricted performance issue as it’s been evident for a while. But having just been out monitoring values it looks like the sensor is faulty. The temp spikes to over 900 when driving, only for a split second. On gentle revs whilst on Park it spikes to over 400. This graph gives you an idea. This is whilst on my drive gently revving
Post #537314 13th Dec 2019 8:05pm
GGDR
M@r]{ if you've read the link spud posted above, you'll see that code definitely isn't the cause of your restricted.
Your car is fairly new, no? Just take it back.
If you bought privately, don't worry restricted without an error is almost always an air/intake leak.
The most common culprit are the four 'donut' hoses - search and you'll find out all about these, or another leak somewhere in this maze:
Smoke testing is pretty easy, or just looking for soot patches on hoses or joints both good places to start. Cheers, Greg
Post #537315 13th Dec 2019 8:12pm
M@r]{
Oh I was all proud of myself that I'd used my £400 tool and found the cause of my problem Confused
Mine's new to me, 2012, bought from a small dealer in Manchester. So taking it back not an option. I do have a WarrantyWise warranty on it. So if it is one of the donut hoses, are they expensive to sort?
Post #537317 13th Dec 2019 8:26pm
M@r]{
BTW that write up on replacing the sensor is legendary!! Fantastic! The rounding off of the sensor is a bit worrying though. Is there any negative effect of this sensor misbehaving like this? If not I'm wondering whether to just leave it be, the idea of it rounding off and needing a manifold off job does not appeal!!
Post #537318 13th Dec 2019 8:33pm
GGDR
Donut hoses - easy job and not expensive.
Most people have this error and it has no negative effect.
I replaced mine and haven't had any real difference or improvement.
Most let sleeping dogs lie.
. Cheers, Greg
Post #537319 13th Dec 2019 8:45pm
GGDR
Do a search on Restricted Performance and you can get the gist of the usual suspects.
There's been a couple this week, including this once which was interesting:
https://www.fullfatrr.com/forum/topic52732.html
/ Cheers, Greg
Post #537320 13th Dec 2019 8:48pm
M@r]{
Fingers crossed it is just one of those silicon hoses. I'll get the engine cover off in the morning and have a look. Found 1m of 70mm hose on ebay for just over £20. If I can get it delivered by next Friday I can ask the garage fitting my starter motor to do those as well Thumbs Up
Post #537322 13th Dec 2019 9:21pm
DrRob
You're definitely doing the right thing and getting all the usual things sorted on it Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #537428 14th Dec 2019 8:09pm
