![]() | Home > General > LR Specialist issues - wrong oils - what to do? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
Most here use the Shell Helix Ultra Professional AF-L 5W-30
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
I would do 2 changes dropping the oil from the bottom connector on the sump., don’t bother with changing the filter on the first change, just loosen it off to let the oil drain down. Then change the filter on the second swap. that should flush the old oil out well enough imho.
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
Thanks Greg!
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 250 ![]() ![]() ![]() |
No idea how it works in Holland, but if you have made a round trip of 4000 km after a documented and 'published' possible oil error then I doubt very much that the garage will in any way stump up for any subsequent rectification.
Thanks NMJ!
Hi Rich,
But you then decided to drive it a return trip of 4000 km, thus you agreed with them!
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8134 ![]() ![]() ![]() |
Not far - you're basically just diluting the wrong oil. A single change will leave a certain amount of residual wrong oil and once mixed with the new oil, a second change would remove the vast majority of that |
brilliant Alistair, thanks! RR Vogue 4.4 TDV8 - 11
Pretty pointless discussion for the two of us to have but...I think that if they´ve put the wrong oil in to begin with and then, intentionally or not, lied about it instead of fixing it - why should I have to pay for the service? Specially as the effect will be me having to spend twice the money again doing double oil changes to rectify their mistakes? Makes little sense to me at least... RR Vogue 4.4 TDV8 - 11 Toyota Land Cruiser Prado - 02 LR Discovery 4 SDV6 -11 - Gone RR Vogue 3.6 TDV8 - Gone |
Get the oil changed
As Alistair said. |
Thanks for all replies and advice!
