![]() | Home > Technical (L322) > L322 Wheel nuts different types? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
It’s to do with the size of the collar on the nut. Earlier cars ->06 are 20mm shank and 06> are 23mm shank, the wheels are the issues rather than the car. Earlier wheels need the thinner nuts, later wheels the fatter ones.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35840 ![]() ![]() |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7996 ![]() ![]() ![]() |
To look at the wheels, I think one type has a dimple in and the others don’t, to identify as per above, but I can’t remember which is which. 2011 Range Rover Vogue SE 4.4 TDV8
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
Thanks chaps. |
this is the wheel that causes confusion..it comes in 2 types, one has dimples around the stud holes and the other has straight through holes..
Are the tapers / mitred ends only on the later type?
yes greg, as per pic.. ... - .- -.
Just checking!
