![]() | Home > Maintenance & Mods (L322) > Klunking noise in the engine bay upon cold startup in my 4.2 |
| friskydog Member Since: 16 May 2018 Location: West Midlands Posts: 78
Ok am I being really stupid here but has anyone uploaded a video to this site as I seem incapable? Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2297
Upload it to YouTube and post a link?
Thanks Dan here is the link to the noise. I have just had my supercharger rebuilt by powerhouse. Have a listen see what you think.
| kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335
Mine sounds like a bit like that, it's got 227k miles on it so probably needs timing chains doing. I also think is has a slight misfire at idle on a cold start and I've read alot do that - Something to look into. As suggested above you should take off the supercharger belt then do a cold start and then take off the main aux belt and do the same. If the noise goes away that will tell you it's supercharger or ancilaries related rather than inside the engine. |
see this thread : https://www.fullfatrr.com/forum/topic53250.html
| MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140
as dan said above,
Guys cant thank you enough so far. I am having it all checked out atm so will update but really good responses thanks ever so much. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles |
no worries,
No worries,
| stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276
To me it sounds more of a plastic/polyethylene clunk type sound.
Just to fuel this fire a little more it appears the noise goes away once the engine is warm. Go figure. Makes it even harder to solve. However all my tests have been whilst stationary.
Let us know if they find anything. Going when warm suggests something warms up and gets back into tolerance, or oil gets somewhere and lubes it. |
Will do, also I have just had an oil and filter change and new oil filter housing seal. I use castrol magnatec fully synthetic 5w 30 A5. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles |
Did it make the noise before the oil change? |
