![]() | Home > Technical (L322) > Do I need the tracking checking? |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
If it were me, yes Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| drakes Member Since: 26 Jan 2009 Location: Consett Posts: 375
Most tyre dealers will check your tracking for free, only charging to adjust, so yes get it checked. Just make sure you use one with a computerised tracker. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
| mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766
Cheers guys, will have a ring around this morning.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883
make sure its a hunter type.... ... - .- -.
| Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417
^^^ what Stan said |
Cheers guys, had it checked and the tracking is out on the passenger side as expected
| RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 250
A 'walk' to Specsavers could also be appropriate. ML 320 7 Seat full leather etc. (The Black Pearl) |
Although it is common practice you should not heat track rod ends to adjust them, or any other suspension components. If a MOT inspector sees evidence of heat he should fail it, obviously if you are heating it in order to remove and replace it that is okay. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
| Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428
Of course, no-one else apart from the OP had had an altercation with a kerb............... 2003 Range Rover Vogue TD6 |
Yeah, the mrs should of run over the poor defenseless fox 2 weekends ago. Cheers for your input |
Cheers all, think for the price I'm going to get both the inners and the outers and do both sides together, will i need anytihng else other than the actual inner and outer for each side? New nuts, or gaiters? |
Inners normally come with nut but the outers sometimes come without so just check when you order. Fairly easy job really, would be worth setting up tracking with a piece of string so that it is in the right ball park for when you drive to the garage to do it properly 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
| gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 287
I’ve read on the disco3 site & RRS that Kwik Fit (for all the negativity) do a good job if they have the Hunter system. Cost wise there is an offer where you can have it done unlimited times for a flat fee over 2 years(?). Hunt for a L405 is on. |
| All times are GMT |
