Home > Maintenance & Mods (L322) > Leave off EPB for storing?
DrRob
As I won't be using the RR for a while (now working from home) is it worth leaving the EPB "off" whilst it's laid up to stop it seizing to the rear discs? I've read somewhere it can be put in "off" by taking out a fuse???
My gut feeling is to just fire it up weekly and use the EPB to keep things working OK. Raise/lower at same time etc.
I have a Ctek into towing electrics which I will use to top up battery every 2 weeks if I don't use the RR...
Thoughts? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #547998 23rd Mar 2020 10:26am
just leave it in 'park'....dont activate the brake. ... - .- -.
Post #548001 23rd Mar 2020 10:31am
DrRob
Thanks Stan. For some reason I thought it came on automatically but that's good to know!
Everyday is a school day Thumbs Up
Bow down Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #548002 23rd Mar 2020 10:33am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Yep. What Stan said.
Jim
Post #548003 23rd Mar 2020 10:33am
Baltic Blue
Rob/ Stan,
I am not 100% certain but I think the EPB does come on automatically on switch off of ignition.
The EPB module then automatically depowers after the vehicle shut down time.
I pulled the emergency release cord on mine a couple of weeks ago when I thought it was stuck on, but it wasn’t.
Watching the red brake symbol on the dash as you apply/ release it is the only way to know.
Post #548005 23rd Mar 2020 11:10am
Baltic Blue
Page 94 in the drivers handbook tells you how to prevent automatic operation.
Mike.
Post #548010 23rd Mar 2020 11:32am
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Thanks Mike.
Mine's all tucked up on a Ctek too, for the foreseeable Big Cry Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #548012 23rd Mar 2020 12:06pm
Baltic Blue
Ditto, but I might just take it out for a run tomorrow while we are still allowed out.
Keep safe Brad Thumbs Up
Post #548015 23rd Mar 2020 12:50pm
Bradders
And you and yours too Mike. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #548016 23rd Mar 2020 12:52pm
interesting Mike..
so theres an auto setting for the epb then...
i think by default the epb is in manual mode??
in all my FF's i had i've only used park [transmission lock] with a few exceptions like the tunnel or parking on a hill.. ... - .- -.
Post #548017 23rd Mar 2020 12:55pm
Baltic Blue
Perhaps I am reading it wrong, but , my interpretation is that when you select Park and switch off ignition it automatically applies the EPB, but as the car powers down, the EPB module depowers to prevent battery drain .
Post #548018 23rd Mar 2020 1:07pm
so when you start and select drive/reverse you have to release the epb?? ... - .- -.
Post #548021 23rd Mar 2020 1:29pm
Baltic Blue
No, you don’t need to touch the brake handle.
Watch the red light , it goes off as soon as you move.
Post #548023 23rd Mar 2020 1:36pm
DrRob
I'll try it later again but I just put into P and then switched off without applying EPB. Locked car.
When I unlocked then switched ignition on again (no start) the red parking light was not on the dash.
I've got it on charge at moment but will look later and see if the EPB has applied. I'll also start and then select D and see if I hear/feel it release. I'll also check to see if the red parking light is on dash when I open/start it.
I bet Craig will be along soon and tells us Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #548040 23rd Mar 2020 4:07pm
DrRob
Just opened it. No red light.
Ignition on. Still no red light.
Switched off and locked.
My assumption is it's now "off".
Will start it later and check again.
Maybe the previous owner already disabled auto function? Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #548046 23rd Mar 2020 4:53pm
