![]() | Home > Maintenance & Mods (L405) > locking wheel nut |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35872 ![]() ![]() |
in the boot under the load cover...on the left under a flap... ... - .- -.
Blackbird Member Since: 22 Feb 2020 Location: York Posts: 26 ![]() ![]() ![]() |
Stan you are a superstar. Thank you very much |
i'll only be a superstar if its actually there and you find it |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
Took me a while!!
It was there Stan but by hell the wheels are heavy to lift back on. |
thats a result. and yes they are heavy |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1482 ![]() ![]() |
You need a set of wheel fitting guides. See here...... https://www.fullfatrr.com/forum/topic43537.html 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
Thanks Rob I will get some guides, they must be a lot easier than trying to lift on. |
there is an easier way to lift the wheel onto the studs...
Thanks Stan, it sounds like I need practice to get the technique right. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
Me: Don't jack it more than needed, line up the studs then a foot under each side.
Thanks Greg will try. I have a trolley jack but only used the one provided with car yesterday. If using a trolley jack where is the best place the jack on the RR. Jim. |
