|  | Home > Maintenance & Mods (L322) > Rear wiper - worn spline? |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | The motor will be just fine as it is... Just replace the arm sir  | ||
|  4th Apr 2020 10:11pm |
| stuartj9 Member Since: 18 Apr 2019 Location: Liverpool Posts: 86      | Thanks for the reply. Does the spline on the motor look OK? It looks a bit worn to me.
|  4th Apr 2020 10:13pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Yes it looks a little worn but put an arm on with decent spline's and im sure it will work fine sir  | ||
|  4th Apr 2020 10:24pm |
| stuartj9 Member Since: 18 Apr 2019 Location: Liverpool Posts: 86      | o you also have a link to Ebay for the correct rubber seal for the motor please? It's slightly leaking inside the car. Thank you. | ||
|  4th Apr 2020 10:41pm |
| stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276      | Here's what I'd do to find the seal.
|  4th Apr 2020 11:00pm |
| stuartj9 Member Since: 18 Apr 2019 Location: Liverpool Posts: 86      | Thanks Stu, that's a great site for parts - bookmarked! It's the wrong seal though. I need the one that connects to the motor and water pipe. This is where it's leaking from. Cheers | ||
|  4th Apr 2020 11:08pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | https://www.fullfatrr.com/forum/topic9792.html
|  5th Apr 2020 12:25am |
| stuartj9 Member Since: 18 Apr 2019 Location: Liverpool Posts: 86      | Cheers. I used the link on there but looks to be gone from Ebay. There's others but I need to get the correct one. I also need the self tappers. | ||
|  5th Apr 2020 3:36pm |
| stuartj9 Member Since: 18 Apr 2019 Location: Liverpool Posts: 86      | All sorted. Spline cleaned with a blade, wiper arm sanded and resprayed and arm now back to the correct position Thanks to everyone that helped.
|  11th Apr 2020 7:42pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
