![]() | Home > Technical (L322) > 4.2 SC lean codes |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 422 ![]() ![]() ![]() |
thats the next bit, charcoal canister and that evap pump, it could cause it but who knows. Its actually a sport |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1403 ![]() ![]() |
You will never get the fuel trims to be zero
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
The only thing is with my charcoal canister I had a vacuum when I opened the fuel tank on the m6 but I don't with this for me this is not a problem I don't think. I just went for a drive to ironically pick up a charcoal canister for my m6 and thought id see my trims for you as not liked for ages as seems ok to drive. So at idle they ar -5 to 0 most of the time - happy with that. light load they come down a little but sometimes spike a bit but not too worries about that. at about 70% load I was getting spikes of 18 - 23 but mainly around 10 - not so happy but it was a very quick spike. Not enough to log a code. 100 % - 0 - which I'm guessing mes it goes open loop as expected as its chucking everying in it can.. Is this similar to yours or different? if similar we probably have the same problem or same non problem at this point ![]() 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
i dont want to reach 0 but an acceptable figure, either +5 or -5 seems good.
i did refurb the injectors btw when it was all off. recently when i put load on it, it spikes to 10ish and stays there till load comes off. Its actually a sport ![]() Not anymore, 4.4 TDV8 now ![]() |
Heavy load like I mentioned? If you are less than 50% throttle
It does. It's a bit odd since it would suggest that it's not getting enough fuel. You can see the fuel trims being at like 15-20% short trim just before it goes into open loop Its actually a sport |
Sounds similar maybe itβs just a poor design or we have the same issue would be good to hear from others Current stable:
i have two ideas that i need to see if are any good |
How are you getting on? Current stable:
i had enough, tuned the lpg myself to basically run a bit richer. its not ideal but fook it. i think my cats have always been shot because if I cruise at a constant speed on motorway like 70 or something i get misfires. petrol or lpg.
a bump from timee ago. it seems my dipstick tube is |
How did you get on did that fix your issues? Was that obvious? I too have an oil leak Current stable:
so when dicking about with the cats, i noticed on the right hand side they didnt use a LR bolt to connect the pipes up but some |
Is that using sdd? How do you get that report? Current stable:
