![]() | Home > Technical (L322) > 4.2 SC lean codes |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2282 ![]() ![]() ![]() |
wouldn't mess about with it until you can do the other sensor.
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 433 ![]() ![]() ![]() |
ive got both sensors with me, its just bank 2 is an absolute monster to get to. this would also provide a clearer picture if the new sensor has made a diff, because i can compare bank 1 vs bank 2 directly then, new vs old. Its actually a sport |
I think I hate this car.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1412 ![]() ![]() |
Is it popping up lean codes? |
Have you some coils and o2 and genuine maf? If not do them all for one bank and see if any improvement? Current stable:
Also I’d join a Jaguar forum for specialist issues like this a popular one as our engine has many many applications and a far bigger user base in these - obviously feed back on here if they help you |
It's not, the worst trim there is 17% and lean codes start at 20%
Everything but the coils, but I'd assume if there was a problem in combustion the subfeedback would show it. I did actually check the jaguar forums here: https://www.jaguarforums.com/forum/general...760/page2/ am literally outta ideas tbh. i wouldn't even mind taking her to a mechanic but people see the lpg and get scared off very quickly. Its actually a sport ![]() Not anymore, 4.4 TDV8 now ![]() |
If it aint popping codes you are worried about nothing, just drive and enjoy.
If you are driving it on petrol Dingg is probably right but if you'd like to drive it on gas id want those a bit lower, I was getting rich codes with bad coils actually so that won't be your issue.
from cold its actually pretty banging. smooth, no issues. but yeah I do want to run her on gas which is why am trying to fix the trims. Its actually a sport |
Do you get lean codes when its running on gas? |
It will do yes, the gas pushes the trims too far Its actually a sport |
fair enough mine are floating around 5-10 last time I looked and I was happy as like ding said these aren't highly refined engines they are big brutes they are never going to be bang on... id love it to be 0 but I think my quest would cost a fortune and would make it one of the only ones |
id be happy with 5-10, but 17 is ridic Its actually a sport |
