Home > Maintenance & Mods (L322) > Locking Wheel Nut - How to remove a damaged one
Superspoons
England 2006 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Hi all,
I had the dreaded 'what monkey tightened this locking wheel nut up' moment this week and thought the following may help someone in the same position I found myself in.
So, genuine Land Rover code 'E' locking wheel nut set on my Fatty. Rear near side locking wheel nut stuck fast. The wheel nut is in two parts and the outer shiny cap part is turning against the inner part causing the locking tabs to not line up. Common issue apparently. Looking inside reveals burred edges around the slots the locking tool fits into. It's probably been spun on by an Air Gun/Gorilla at sometime destroying the slots with too much torque. The rear brake pads were last changed by a Land Rover Dealership just before I bought it in September last year...
You will need -
Patience
Dremel drill and 38mm steel cutting disk
A steady hand
Chisel
Lump Hammer
Locking wheel nut removal kit
Breaker Bar
Suitable protection equipment for your eyes and hands. I'm not responsible for you lopping off a finger or getting something in your eye - that's for you to decide.
So, first point of call. A Dremmel with a 38mm Steel cutting disk on it -
Very carefully cut a slot across the face of the locking wheel nut avoiding touching the alloy wheel. You'll need it running quite fast as the steel cap is pretty hard -
Once you've cut as far as you can, place a suitable sized chisel in the slot and give it the opportunity to meet its maker...
....with Land Rover tool number 1 (aka a nice lump hammer) -
After a few suitable ahem, 'taps' it will break away - hope you've got your eye protection on, just in case. If you're unsure of your Fatties whereabouts lately, wear a mask too. Stay Safe -
Remove as much of it as you can -
The remains of the cap -
Your Wheel nut will now resemble something like this - gnarled and horrible -
Next step is to use the socket in a kit to remove the bolt. I picked this up on Amazon for £22 -
https://www.amazon.co.uk/gp/product/B082H8...&psc=1
Once on the remains of the locking nut they 'dig'' onto it as an anti clockwise force is applied. Multiple sizes for different nuts -
I used the 17mm one on the stump and hammered it on until it was against the collar of the nut - you will feel it bottom out -
Now, get a suitable bar on it and with the right amount of pressure you will hear a pleasing 'crack' as the socket digs it and breaks the loving relationship the wheel had with the locking wheel nut. Take it easy at first to give the socket time to dig in properly -
"Victory on the Driveway" as it is a very special day. Its off. What a mess it is too -
Clean up the area, Have a cup of tea and maybe a biscuit. You've done well and its 1-0 to you - to avoid a repeat get on the internet and buy yourself 4 new wheel studs and replace the other 3. Throw your lockers away!
You know it makes sense.
cheers,
Gavin Gavin
2005 Range Rover Vogue SE 4.2 Supercharged V8
Follow my 4.2 Supercharged antics -
https://www.fullfatrr.com/forum/topic63354.html
https://www.instagram.com/l322_supercharged/
https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg
https://www.youtube.com/@ChallengingClassics
Post #553133 8th May 2020 8:36am
Parallel
Excellent, informative write up and the right amount of humour thrown in too. Great work Thumbs Up
Post #553140 8th May 2020 9:24am
Rob99
Good job Superspoons Thumbs Up Thumbs Up
Reminds me to go check mine again. Have always meant to bin the locking wheel nuts but never got round to it. Rolling Eyes Rolling Eyes 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #553142 8th May 2020 9:30am
Top job... First thing I do with every car I get, take the locking nuts off and throw them away, waste of time in this day and age...! Pete
-Click here for Thread-
Post #553144 8th May 2020 9:35am
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Good job and great write up Thumbs Up Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #553162 8th May 2020 12:02pm
WB
I had the same issue on my previous TDV8 with a tyre place who couldn't get the locking wheel nut off and said I'd have to get it cut off. I wasn't convinced so removed another wheel's locking nut and had a closer look.
I discovered that it wasn't necessary to cut it off and after spending a few minutes patiently realigning the outer (spinning) cover with the inner notches the locking wheel nut then solidly engaged. So while the method above can be used it's not always necessary to cut anything off.
The method to realign is:
1. Test the locking wheel nut.
2. If it doesn't fit then spin the outer cover a few degrees and retest being careful not to nudge the outer cover.
3. If it doesn't fit then repeat step 2
You need to be patient with it but it doesn't take long.
Post #553168 8th May 2020 1:16pm
Superspoons
Hi WB,
Yes, agree and had tried that - I even bought a new locking wheel nut removal key from MPS Trading to try that as my original one was badly burred in places. I could spin the outer part around to the get the outer and inner lugs to line up but it still wouldn't budge Sad It just lifted off every time I tried to undo it - it was really on there tight and the damage to the lugs was pretty bad. I guess its a case of each nut has its own level of damage and corresponding fix.
cheers
Gavin Gavin
Post #553217 9th May 2020 6:46am
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Good job. You did well not to mark the wheel!
Post #553222 9th May 2020 7:44am
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Chapeau! Now never put back another one. Took them off of all my cars, when they where on. Thumbs Up
Post #553237 9th May 2020 11:52am
