|  | Home > Technical (L322) > Tow bar electrics |
| kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 229      | There is a white socket in the right rear corner that the factory kit plugs into, you might find somebody like PF, Jones also have a kit thats plug and play, having fitted several tow bars for different people over the years I had a voltage sensing relay, spare socket and enough wire to make my own up. | ||
|  18th May 2020 8:05pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | Open the cover on the plug on the car.
|  18th May 2020 9:33pm |
| Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172      | If it is 16pin I have a convertor which is of no use to me any longer. 2011 4.4tdv8 Vogue
|  18th May 2020 10:21pm |
| Dizzy Dee Member Since: 26 Dec 2017 Location: London Ish Posts: 96      |
 Of you mean the socket on the rear of the car, then it will be 7 or 13 pins. Like below.   | ||
|  19th May 2020 6:23am |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | Sorry, late night brain fade....  | ||
|  19th May 2020 6:37am |
| steve1 Member Since: 29 Jan 2018 Location: manchester Posts: 56      | It's the 12n as above with no other plugs in the vicinity | ||
|  19th May 2020 10:38am |
| diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 491      | Here you go Steve, that would replace the lot, or you could just search for the single 12 N with ECU box, but that seems a good price to me, and you'll get all the instructions to fit it too.  | ||
|  19th May 2020 10:48am |
| steve1 Member Since: 29 Jan 2018 Location: manchester Posts: 56      | Cheers Dave I'll get on with that many thanks | ||
|  19th May 2020 11:15am |
 I do have a 15 pin on my trailer and truck, stops other folk towing it.  Like this.   | ||
|  19th May 2020 7:57pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
