![]() | Home > Maintenance & Mods (L405) > L405 Roof bars recommendations with no rails |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
I have got a pair of Thule roof bars for my L322 that fit in the door openings and then pull down on suction feet.
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135
Thule don't list any.
| palli Member Since: 27 Oct 2017 Location: Suffolk Posts: 42
I queried with Thule why there were no roof bars for my vehicle. Their reply is below
| Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268
https://rover.ebay.com/rover/0/0/0?mpre=ht...2737714488
| Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158
I had this exact same problem with my 405. I spent a load of cash on the OEM roof rails to then fit cross bars.
Thanks that is very useful to know indeed!
Seems reasonable that you could design & fabricate something to use the mountings for the rails.
Also, if you're doing a full build, then be sure to post up a dedicated thread like the one Haylands did for his |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
For my L322 I made up some roof bars out of galvanised unistrut on purpose made mounting blocks that screw into the roof fixings without having to break off the fixing cover flaps.
| pherplexed Member Since: 27 Apr 2010 Location: SC, USA Posts: 70
Charles89 - I've got the factory roof rails and have successfully fitted Thule crossbars and a Rhino Rack platform/basket...overall, a very low profile setup.
Thank you for taking the time to share, that is much appreciated |
The official rating is usually limited by what you could happily do a slalom course with - and is governed by vehicle dynamics as much as anything else.
What Alistair said. LR say the max load for the SWB roof rails is about 100kg, but that seems low to me. 2021 P525 | Eiger Gray |
| PaintHorseOne Member Since: 25 Nov 2019 Location: Minnesota Posts: 1
Wondering if anyone has considered the EZ-Awn Roof Rack Rail set. https://www.equipt1.com/collections/roof-r...-rack-rail
