Home > Technical (L322) > No squirt rear wiper?
Anvil
I just took a little red rubber gasket out of my NRV -it had perished. washer works fine now, although you do have to keep it on for a couple of seconds until water comes through. not long enough to worry about though.
Thumbs Up FFRR 4.2SC/KTM 990SMT Current and cherished.
Honda Accord 2.4 Vtec touring. (Yeah, I know, think: Kids)
Mitsubishi Pajero Evolution Nut-wagon. and a Buell XB12R
TVR Griffith 5.0 (backed up with Vauxhall Carlton road barge for the weekly shop.)
Honda Integra Type R DC2 Possibly the best drivers car. Ever.
Mitshibishi FTO GPX MIVEC.
Honda CRX Vtec Mk2 -NO, Not the del sol!!!
Volkswagen Scirocco GT
Mini 1275GT
MG Midget (Heavily modified)
I'm going to stop now.....
Post #571333 30th Oct 2020 5:41pm
Jayk69
Nice one just replaced the rear wiper!! and notes water not flowing properly. will be a job to do this weekend Smile
Post #571340 30th Oct 2020 6:54pm
Danwilderspin
Right back on this. Where does the rear window water tube run? On the new headlining I have replaced the old with it ran across the headlining (from a 2012 car) but when I took down my headlining a couldn’t see it? The new one looks like it ran down the passenger pillar again couldn’t see it? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #572760 14th Nov 2020 11:26am
Jimnic007
United Kingdom 2012 Range Rover Vogue TDV8 Nara Bronze
Which way should the arrow be pointing on the NRV? Does it point towards the motor, or away from it?
Thanks
Post #572804 14th Nov 2020 6:03pm
ur20v
A Trap
Arrow points in the direction of flow, points to the wiper motor/arm/jet
Post #572809 14th Nov 2020 6:41pm
Jimnic007
Thanks. I think this may be blocked, as every time I squirt it, the hose pops off from the force of the water .
Post #572812 14th Nov 2020 6:53pm
ur20v
A Trap
Mine can be taken apart with two small jewelers screwdrivers. Had to back flush the washer jets as they had calcium build up and kept blocking after cleaning the jets with a needle
Post #572814 14th Nov 2020 7:14pm
Jimnic007
Thanks.
Do you have to take the wiper arm off to properly clean the nozzles/jets? My NRV looks like a sealed plastic unit, with no hole running through the middle.....
Post #572820 14th Nov 2020 8:01pm
Danwilderspin
Ok my non return was damaged trimmed the gasket now it pours water out of the inlet from the motor...
Thinking of doing this any issues?
Would a bead of silicone around it do the same job?
https://www.fullfatrr.com/forum/topic9924.html Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #572884 15th Nov 2020 2:50pm
Ashmyster79
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I did mine last week. The motor was caked in mud. I took the whole motor apart you can see where it is clogged from there backwards. As above mine leaks water from where the non-return value sits on the motor body an ever so slight gap. I silicone it a little but have yet to test the water. when I did pre silicone it went in the plastic tray. I used some compressed air, pipe cleaners and a metal skewer from the bbq to clear it all. If it's blocked further back I wonder if there is a kit to pressure flush through the tube from front to back. I am not clever so apologies if this is not possible.
Post #573200 17th Nov 2020 2:37pm
