Home > Technical (L322) > What is this pipe?
Jack last
United Kingdom 2005 Range Rover Vogue Td6 Zermatt Silver
What is this pipe?
Anybody know pipe in middle of pic just noticed it’s
not connected to anything
Post #572684 13th Nov 2020 3:18pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Have you a photo showing a little bit more of the engine. I can’t work out where you are looking?
Jim
Post #572691 13th Nov 2020 5:41pm
mjdronfield
I’m guessing it’s a breather, but need a pic from further back.... as can’t tell exactly where that is....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #572692 13th Nov 2020 5:41pm
Jack last
Hi yes the picture has uploaded sideways
As I look at it from front of the car it’s heading in direction of the bulkhead
Post #572695 13th Nov 2020 5:56pm
mjdronfield
There is a gearbox breather, but I think that might have a filter on, that goes nowhere. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #572703 13th Nov 2020 6:47pm
Jack last
So not needed then?
Post #572705 13th Nov 2020 6:54pm
mjdronfield
Well it’s needed, just not connected to anything. Best not to look for issues. They will find you soon enough 🤣 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #572707 13th Nov 2020 7:07pm
Jack last
Well it’s running fine just no brakes that’s another story!
I’ll keep an eye on it Big Cry Laughing
Post #572709 13th Nov 2020 7:12pm
stuart_2006
Wisdom elsewhere on the forum suggests that pipe is the breather for either the transfer box or the front diff (and it should be clipped onto that clip right next to it). There's another plastic pipe nearer the back of the engine that comes up and is bent in a semi-circle so the open end points down - that's the other breather. There's also a small clear plastic filter in that area that is open at one end - that's the gearbox filter.
Post #572717 13th Nov 2020 8:07pm
Jack last
Hi there Stuart so how many connections do I have to make here exactly?
Can you add arrows to my pic to show me where you mean?
Thanks
Post #572720 13th Nov 2020 8:12pm
stuart_2006
Well you don't have to make any connections ... all the pipes are designed to be open at the end in the engine bay.
This thread shows the pipe you've found plus the gearbox(?) breather: https://www.fullfatrr.com/forum/post210674.html
The 2nd picture in this thread shows the third of the breathers: https://www.fullfatrr.com/forum/topic50389.html
Post #572731 13th Nov 2020 9:40pm
Jack last
Ah ok so all is well then
Thanks Thumbs Up
Post #572732 13th Nov 2020 9:46pm
Weegie
They are open end so they can breath. They are up where they are so that the gearbox/transfer boxes don't flood when wading. John
GAP iiD BT-Sold
Post #572750 14th Nov 2020 8:02am
