![]() | Home > Technical (L322) > 4.4 tdv8 turbo replacment |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2625 ![]() ![]() |
You’d hope so given an L322 is monocoque! |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Yes. I had my secondary one changed at Rovertune due to it leaking and no body off Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7996 ![]() ![]() ![]() |
The body can’t come off. It doesn’t have a separate chassis. If a garage says body off, use a different garage 🤣
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 159 ![]() ![]() |
It is similar to body off. It’s a subframes that the engine is mounted on and can be dropped out for work access. However dropped out is quite a simple term for the task! |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
I’ve also had the secondary turbo replaced. No need to drop subframe, engine stays in situ 2011 TDV8 Vogue SE |
