Home > Technical (L322) > New Rave CD or help required on Handling management fault.
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Can anyone guide me to either renewing my Rave CD (I cannot run anymore), or telling me where the abs valve relay is. It keeps coming up as a fault when the system involving abs traction control suspension inactive etc. This occurs when I accelerate at a junction or corner fast enough to trigger all the handling controls . It all clears after an ignition switch on/off. So it triggers in , surely it would cancel and revert back to normal, but it doesn't and sends a fault
Post #573488 19th Nov 2020 9:20pm
mjdronfield
There are reports of RAVE no longer working on versions of Windows 10, if that’s what you are using.
Can’t help with other bits, sorry.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #573497 19th Nov 2020 9:51pm
Not sure what you mean by the ABS valve relay ?
The pressure sensor is on the ABS modulator in the engine bay, the DSC sensor is under the centre console inside the car.
Fuse F55 covers the ABS ECU
Maxi Fuse MF63 also covers the ABS ECU
no mention of any relay.... .
Post #573498 19th Nov 2020 9:56pm
p38arover
Australia
Correct, RAVE no longer runs on WIN 10 later than 1903. One needs the hacked version that will run with standard versions of Acrobat. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #573501 19th Nov 2020 10:02pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
That's not correct, you need to change the compatibility mode for the program to run.
Right click on Rave application, click on compatibility tab.
Don't bother running the compatibility trouble shooter, instead select Windows 98/windows Me and click on apply. Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #573505 19th Nov 2020 10:22pm
alfapat
That’s great I’ll try that. it just goes no further than Acrobat.
The fault that comes up with Gap is abs valve relay. That’s what I’m going on.
Post #573513 19th Nov 2020 10:47pm
alfapat
That’s excellent now running. And searching my problem , but no abs relay . Thanks for that clever conversion.
Post #573520 19th Nov 2020 11:19pm
alfapat
Going back to my original problem, and looking for relays , there is on listed in the abs electrical circuit , but can’t find it on the car . I have also picked out a 5 amp fuse that was in the wrong place so that wouldn’t help . Not sure if the anti lock brakes are working come to think of it, so will test that tomorrow.
Post #573670 21st Nov 2020 5:34pm
p38arover
Australia
Odd, I tried it again today with Win 10 1909 and it works. Smile (Mine is a genuine RAVE disc
V015-2
I tried this with several of my RAVE discs and none brought up the compatibility tab when I right clicked on RAVE.EXE. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #575788 12th Dec 2020 7:20am
bigbo
I don't run direct from the cd, I copied to my PC and created a shortcut on my desktop. I then applied the compatibility on that shortcut.
Hope that helps. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #575830 12th Dec 2020 2:24pm
