Home > Technical (L322) > New Rave CD or help required on Handling management fault. |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
Can anyone guide me to either renewing my Rave CD (I cannot run anymore), or telling me where the abs valve relay is. It keeps coming up as a fault when the system involving abs traction control suspension inactive etc. This occurs when I accelerate at a junction or corner fast enough to trigger all the handling controls . It all clears after an ignition switch on/off. So it triggers in , surely it would cancel and revert back to normal, but it doesn't and sends a fault |
19th Nov 2020 9:20pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7638 |
There are reports of RAVE no longer working on versions of Windows 10, if that’s what you are using.
19th Nov 2020 9:51pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Not sure what you mean by the ABS valve relay ?
19th Nov 2020 9:56pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
Correct, RAVE no longer runs on WIN 10 later than 1903. One needs the hacked version that will run with standard versions of Acrobat. Ron B. VK2OTC
19th Nov 2020 10:02pm |
That’s great I’ll try that. it just goes no further than Acrobat.
19th Nov 2020 10:47pm |
That’s excellent now running. And searching my problem , but no abs relay . Thanks for that clever conversion. |
19th Nov 2020 11:19pm |
Going back to my original problem, and looking for relays , there is on listed in the abs electrical circuit , but can’t find it on the car . I have also picked out a 5 amp fuse that was in the wrong place so that wouldn’t help . Not sure if the anti lock brakes are working come to think of it, so will test that tomorrow. |
21st Nov 2020 5:34pm |
Odd, I tried it again today with Win 10 1909 and it works. (Mine is a genuine RAVE disc V015-2
I tried this with several of my RAVE discs and none brought up the compatibility tab when I right clicked on RAVE.EXE. Ron B. VK2OTC 2004 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
12th Dec 2020 7:20am |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 541 |
I don't run direct from the cd, I copied to my PC and created a shortcut on my desktop. I then applied the compatibility on that shortcut.
12th Dec 2020 2:24pm |
