Home > General > Laughable Question About Sport Mode..
Classic Matt
I am fully prepared to be laughed at for asking this but...
On a 4.4 TDV8 with the rotary gear selector, can you put it into Sport mode on the move?
Every other car I have driven with Sport mode has just allowed you to knock the selector sideways or similar to engage it but as the rotary selector requires pushing down to then allow it to be turned into Sport mode I just thought I'd check before I risk breaking anything. I can't see why it would be any different to taking over with the Command Shift paddles but I'd rather face ridicule on here than another garage bill!
Thank you,
Matt. 2010 L322 4.4 TDV8 Autobiography - SOLD
Post #575929 13th Dec 2020 11:30am
mpirie
Yes you can.
Once you're moving in "D", push the controller down and turn clockwise so it goes into "S".
Mike
Post #575934 13th Dec 2020 11:59am
Placing the 4.4 into sport mode is more like a supersport mode on these models... You'll find the car holds gears way up into the rev range and turns the whole car angry! I believe this is why they put the extra step into engaging sport mode, sir... So it's not done accidentally? Thumbs Up
Post #575935 13th Dec 2020 12:29pm
Jayk69
does it really make that much difference?
not tried it yet might have a go Thumbs Up 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #575941 13th Dec 2020 1:11pm
Holds gears longer.
It’s a gearbox mode, does nothing to the engine or suspension at all. never really saw the point tbh, especially as the paddles work in D.
So you have:
1: D
2: Flappy paddle D
3: S
4: Flappy paddle S
1 works for normal driving, 2 works for spirited driving, 3 is supposed to be for what? A relaxed spirited drive? If you are on a mission then just use 2. 4 has no point at all as it works pretty much the same as 2.... There is nothing that can't be fixed with a hammer😜😜
Post #575942 13th Dec 2020 1:22pm
rjff
+1 with Craig on "angry"
Try it you'll Mr. Green Cheers
Richard
Gap IIDBT
Post #575944 13th Dec 2020 1:24pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
I have no facts for it; but on my 5.0SC sports mode also seems to alter throttle response. At least it feels like it as the throttle barely needs touching compared to non sport. The dampers are dynamic anyway Smile And I also have a button to open the valves of the exhaust for a straight pipe 😎
But it’s nothing like what is actually called super sport on the Mercedes AMG we had. Not that is unleashing the beast. Not just remake the gearbox, but also throttle and notable the steering; lowers the car, changes the damping, opens the exhaust valves, changes the colour of the dashboard, engages active seat support, and most importantly remake the drive train to have 80 of the power on the rear wheels.
Land Rover is very tame in my opinion.
Post #575957 13th Dec 2020 2:03pm
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
The problem I find when using the flappy paddles in "D" is that as it wants to change up at such a low RPM, you find that telling it to change down is mostly pointless, as the gearbox changes back up almost immediately.
With it in S it'll hold onto the gear for longer and so telling it to change up or down is a bit more useful.
Post #575959 13th Dec 2020 2:09pm
Classic Matt
Okay great thanks all. I will give flicking into S a go tomorrow.
I do like being able to use the paddles to get ready for overtakes etc but do then find it frustrating when the car decides to take over again if I haven't changed gear for a few moments e.g. ready to overtake, flick down, change in traffic conditions means opportunity delayed but I want to stay ready, car takes over before I can make the manoeuvre.
Matt 2010 L322 4.4 TDV8 Autobiography - SOLD
Post #575962 13th Dec 2020 2:21pm
Only Time I ever use S is when towing to get the car to hold a higher gear than it wants to in D. I agree that in S it does hold the manual selection properly, but tbh I don’t find myself driving in a way which requires much in the way of holding a lower gear.
If I want to hold a lower gear, or drive in a spirited way, then I drive the other car..... There is nothing that can't be fixed with a hammer😜😜
Post #575969 13th Dec 2020 3:12pm
DrRob
S holds it in gear longer. I use it on slip roads to get above 2500rpm to regulary clear second turbo pipelines Laughing Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #575980 13th Dec 2020 4:32pm
Siftah
"Just clearing the second turbo pipelines officer, honest"
Rolling with laughter
Post #576004 13th Dec 2020 6:18pm
diesel Dave
Happy to be corrected but I thought sport mode also stiffened the dampers, mine feels tighter when driven spirited on bendy roads when in sport mode.
Post #576040 13th Dec 2020 11:22pm
Nope. Does nothing to the dampers. It feels tighter when you drive in a spirited manner, because they are adaptive, they tighten up when you give it some... There is nothing that can't be fixed with a hammer😜😜
Post #576041 13th Dec 2020 11:27pm
The more you give it, the tighter it becomes! OOH ERR MISSUS! Laughing
Post #576044 14th Dec 2020 12:10am
