![]() | Home > My Range Rover > Back with another Supercharged |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
David, the tow bar receiver did you pop the cap off the top before having it shot blasted? if so was it easy to get off?
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3332 ![]() ![]() ![]() |
I did, my tow bar wasn't in the receiver so I popped it out with a long 1/2" extension.
Few more jobs done today...
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Looking good.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
Excellent refresh Dave. There is nothing that can't be fixed with a hammer😜😜
No, even with the bonnet open, the noise isn’t loud. It’s most noticeable with the bonnet open and engine cover removed. David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior 2013 Range Rover Sport SDV6 HSE Black Edition in Santorini Black with Ebony Interior Last edited by dhallworth on 22nd Feb 2021 11:43am. Edited 1 time in total |
I moved the SC to give it a wash today and noticed that the rear window was steamed up.
How’s the boot seal look? There is nothing that can't be fixed with a hammer😜😜
I had a good feel around it and it felt ok but seeing as the car hasn’t been driven, there’s not a lot else it can be as far as I can think of. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Had it’s first bath today. Was a bit OTT with it and did a 5 stage wash.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
As for 13 pin towing electrics, after buying my FFRR, went to tow a new horse box, found it was 13 pin, found a conversion connector, plugs into my electrics, then plug 13 pin from trailer into that, worked perfectly. Best bit was it was about £7, cheap like me!
Thanks. |
I work on vlcc's deep sea, so we always have loads of bearings, for inside fitting, we always freeze them to minus 20/22,and for fitting bearings on shafts etc,we heat the bearings, usually by induction ( and / or freeze the shafts ), at home only way to heat is in oven or place in poly bag and heat in hot water, with sealed bearings, general rule of thumb is only heat up to 85 to 90 degree max
Was thinking of going black for my Wheels now i have seen yours i think i will stick with Silver |
