![]() | Home > Maintenance & Mods (L322) > Broken wheel stud on l322 |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 537 ![]() ![]() |
Hi Shawser,
Shawser1203 Member Since: 29 Jul 2017 Location: Aberdeenshire Posts: 88 ![]() ![]() ![]() |
Yeh it's a nasty one. I've been looking on you tube and seems best way is to drill it out, then replace the stud. Did think a small hole saw might do it. Drill in and cut the shoulder off. |
stuart_2006 Member Since: 18 Jul 2018 Location: Holsworthy, Devon Posts: 131 ![]() ![]() ![]() |
Is there room around it to fit a 'rounded bolt extractor socket' - the type that bites onto the outside with a reverse thread? Or is it deep in a recess in the wheel? |
A large hammer and a long 12mm bolt. |
Unfortunately the stud isn't separate from the hub. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8706 ![]() ![]() ![]() |
If you have genuine wheels then your nuts should look like this...
That's a good suggestion, if (as you say) the tool will fit down the wheel 'hole'. I have a set of Irwin ones, but never found them to be much good on anything I've ever tried. I did see this video on YouTube by Project Farm (who I think brilliant BTW), demonstrating other brands with some pretty impressive results though: Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
They are aftermarket wheels. |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 609 ![]() ![]() ![]() |
If it was me I would split the remains of the nut. To do this I would accurately drill small holes as close together as possible starting as close to the hub bolt as possible.
Having looked at that picture, there doesn't seem to be anything left to get hold of. It's all in the taper of the wheel mounting hole.
Yip, you have to replace the hub. I'll try drilling it first. |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Depends how handy you are with tools I guess.
The hole saw worked. 4mm pilot hole in stud, then 20 mm hole saw. Slight enlargement to hole in the wheel, but nothing to be concerned about. |
