![]() | Home > Technical (L322) > Hood not opening. |
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 ![]() ![]() |
Assuming yours is left hand drive and the bonnet release lever is on the left (Drivers side), Jack up the same side front wheel, remove the fastenings and pull down the plastic wheel arch liner, then reach up with your hand to the area around the headlamp. You should be able to feel the release cable, or what's left of it. As long as it hasn't snapped at the bonnet catch end you should be able to give the cable a tug and it will then open.
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Thanks
