Home > Technical (L322) > FBH, a Range Rover saga |
Harvenberg Member Since: 09 Apr 2020 Location: Stockholm Posts: 23 |
The car is a L322 from 2011 with the 4,4 TDV8 Diesel. |
10th May 2021 1:20pm |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 |
From what I understand, the fuel burning heater isn't supposed to kick in unless the outside temperature is 5 degrees C or below 2011 TDV8 Vogue SE |
10th May 2021 2:31pm |
It does start when the engine is running when the outside temp is below 8 degrees for the diesels (something like that).
11th May 2021 6:32am |
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 |
I am not sure which version FBH the 2011 has ? is it the Webasto Thermotop C ? L322 2007 TDV8 3.6 |
11th May 2021 8:13am |
11th May 2021 11:03am |
I'm not sure either but it seems that my actual heater is working as it should, I'm more confused to why it starts ventilation instead of heating? |
11th May 2021 11:04am |
When you say it is working when you start the RR. Do you mean you can hear the FBH fan running or you know that the burner is working...? L322 2007 TDV8 3.6 |
11th May 2021 3:38pm |
I can hear the fuel pump working. |
11th May 2021 4:01pm |
